XML-DA. Subscription is canceled unexpectedly
18 May 2020 07:10 #8491 by Andriy
Thank you for your advice. I enabled debug logging and found unsubscribe/subscribe requests that probably caused that issue.
13 May 2020 07:14 #8481 by support
Do you call SubscribeItem/SubscribeMultipleItems multiple times, or just once?
If multiple times, is it with the same, or different group parameters (update rate etc.)
11 May 2020 12:24 #8478 by Andriy
The attached screenshot is a result of "GetStatus" call
    10 May 2020 16:54 #8477 by support
    there are many reasons that can cause SubscriptionCancel.
    First thing to find out is what are the results of GetStatus calls, especially between Subscribe and SubscriptionCancel. Can you post those as well?
    08 May 2020 16:35 #8474 by Andriy
    While investigating a communication between my application and Siemens OPC XML-DA Gateway server, I found a lot of subscription cancellation requests. They happen immediately after receiving a response to the subscribe request . The response of the OPC server is very slow. I don't know what is wrong. Could you help me?
    QuickOPC 5.58.151
    Isolated = true
    IsolatedParameters.UseAdvancedPolledRefresh = false
    1. Subscribe request
    2. Subscribe response
    3. Next 2 telegrams are related to "GetStatus" call
    4. Subscription cancel request
