Get event state during event handling
28 Apr 2020 08:24 #8409 by KrisSik
Code you provided works:
UAFilterElements.SimpleAttribute(UAObjectTypeIds.AlarmConditionType, "/ActiveState"),
Kristian
27 Apr 2020 14:28 - 27 Apr 2020 14:28 #8406 by support
Yes, you are right, this is done using the Select clause.
The Active state is not present in all Events. In fact, not even in all Conditions. The conditions needs to be of the AlarmConditionType (see UA Spec 1.04 Part 9, chapter 5.8.2). In AlarmConditionType, there is ActiveState variable.
Assuming that this is what you are dealing with, you should be able to modify the example for Select clauses ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0in%20an%20event%20filter.html ) accordingly. Here is how it looks currently:
// This example shows how to select fields for event notifications. using System; using System.Collections.Generic; using OpcLabs.BaseLib.OperationModel; using OpcLabs.EasyOpc.UA; using OpcLabs.EasyOpc.UA.AddressSpace.Standard; using OpcLabs.EasyOpc.UA.AlarmsAndConditions; using OpcLabs.EasyOpc.UA.Filtering; using OpcLabs.EasyOpc.UA.OperationModel; namespace UADocExamples.AlarmsAndConditions { class SelectClauses { public static void Main1() { UAEndpointDescriptor endpointDescriptor = "opc.tcp://opcua.demo-this.com:62544/Quickstarts/AlarmConditionServer"; // Instantiate the client object and hook events var client = new EasyUAClient(); client.EventNotification += client_EventNotification; Console.WriteLine("Subscribing..."); client.SubscribeEvent( endpointDescriptor, UAObjectIds.Server, 1000, new UAAttributeFieldCollection { // Select specific fields using standard operand symbols UABaseEventObject.Operands.NodeId, UABaseEventObject.Operands.SourceNode, UABaseEventObject.Operands.SourceName, UABaseEventObject.Operands.Time, // Select specific fields using an event type ID and a simple relative path UAFilterElements.SimpleAttribute(UAObjectTypeIds.BaseEventType, "/Message"), UAFilterElements.SimpleAttribute(UAObjectTypeIds.BaseEventType, "/Severity"), }); Console.WriteLine("Processing event notifications for 30 seconds..."); System.Threading.Thread.Sleep(30 * 1000); Console.WriteLine("Unsubscribing..."); client.UnsubscribeAllMonitoredItems(); Console.WriteLine("Waiting for 5 seconds..."); System.Threading.Thread.Sleep(5 * 1000); } static void client_EventNotification(object sender, EasyUAEventNotificationEventArgs e) { Console.WriteLine(); // Display the event if (e.EventData == null) { Console.WriteLine(e); return; } Console.WriteLine("All fields:"); foreach (KeyValuePair<UAAttributeField, ValueResult> pair in e.EventData.FieldResults) { UAAttributeField attributeField = pair.Key; ValueResult valueResult = pair.Value; Console.WriteLine(" {0} -> {1}", attributeField, valueResult); } // Extracting a specific field using a standard operand symbol Console.WriteLine("Source name: {0}", e.EventData.FieldResults[UABaseEventObject.Operands.SourceName]); // Extracting a specific field using an event type ID and a simple relative path Console.WriteLine("Message: {0}", e.EventData.FieldResults[UAFilterElements.SimpleAttribute(UAObjectTypeIds.BaseEventType, "/Message")]); } } }
and you would include something like
(not tested)
Let me know if that works for you, please.
Last edit: 27 Apr 2020 14:28 by support.
The following user(s) said Thank You: KrisSik
27 Apr 2020 09:36 - 27 Apr 2020 09:43 #8403 by KrisSik
I am trying to get event's active/inactive state in the OpcClientOnEventNotification(object sender, EasyUAEventNotificationEventArgs e) event handler, but have no success in that, could you please help me?
I was expecting to see that attribute in the e.EventData.FieldResults, but that is not present in this dictionary. Maybe I need to configure the select clause while subscribing? For subscription I use SubscribeMultipleMonitoredItems method.
Kristian
Last edit: 27 Apr 2020 09:43 by KrisSik.
