Writing to tag failed with error code 0xC0048005
18 Apr 2020 08:05 #8377 by support
I have some questions.
1. When writing to this tag, does it happen always, or only sometimes?
2. Have you used some other OPC Client to test the same thing, and if so, what were the results?
3. What is the result if you remove the last argument altogether (VarType.Bstr)?
In general, this error code is not generated by our software anywhere. It must be an error that comes from the underlying DCOM APIs, or the target OPC server.
17 Apr 2020 07:44 #8376 by nrsouman
I'm getting an exception "0xC0048005 + The client method called was 'WriteMultipleItemValues'" when attempting to write to a tag using EasyDAClient.WriteItemValue. The code looks like this:
EasyDAClient.WriteItemValue("1.1.1.1", " ABB.HarmonyOPCServer", "fulllotno", "123456789",VarType.Bstr);
The string value is a lotnumber which always has the same length and is never empty. Unfortunately this doesn't always happen and when writing to our test OPC server (Kepware) this has never happened.
I can't find this exception in the documentation. Could someone explain what this exception means?
Neil
