Exception using == equality operator against null
23 Oct 2019 16:11 - 23 Oct 2019 16:11 #7862 by support
Which QuickOPC version are you using? (I cannot rule out that some versions could have the operator '==' defined on easyAEClient, and the exception is coming form inside its implementation)
Anyway, first thing to do to rule this out: Replace these tests by
ReferenceEquals(aeClient, null)
or, in newer C# versions,
aeClient is null
This way no unexpected code can be called for the comparison. And let's see if that helps.
Last edit: 23 Oct 2019 16:11 by support.
23 Oct 2019 15:21 #7860 by fancybird
Hello ...
Sometimes, we get an exception when checking for aeClient == null.
It does not always happen ... but it happened enough that we had stayed away from doing that.
We had been using a separate variable to track if aeClient had been instantiated.
Is that normal? I am just curious.
Thanks!
Time to create page: 0.178 seconds
