OPC XML-DA. Error: The item value does not specify a timestamp.
15 Oct 2019 09:12 #7827 by support
Please download and rebuild with the latest QuickOPC 2019.1, build 422.1 or later, as on our Web page and NuGet.
We have made the code more forgiving in this respect. Missing timestamp in the case you have described should no longer cause an exception.
03 Oct 2019 07:59 #7787 by Andriy
I agree, it's a mess. Therefore, I will create separate topics for issues #2 and #3.
I was able to reproduce an error: "The item value does not specify a timestamp."
QualityField="badWaitingForInitialData"
QualityField="good"
    02 Oct 2019 15:35 #7786 by support
    In the future, please put each issue into its separate forum thread. It is really important. We now have 3 issues here, under an incorrect title. It is a mess. . To sum it up, they are:
    1. OPC XML-DA. Error: The item value does not specify a timestamp.
    2. Number of open sockets.
    3. commFault in getStatus call.
    If they are related, links can be used to provide the relationship.
    Regarding the number of sockets: Does it grow without a limit, or does it stabilize at or around certain number?
    02 Oct 2019 14:52 #7785 by Andriy
    Vendor info:
    Arosii OPC XML-DA framework, Nordex RFC OPC XML-DA Gateway
    I cant reproduce the issue "The item value from OPC NET API (Data Access) does not specify a timestamp." anymore.
    It happened with All items but only once when "ItemChanged" notification was triggered first time.
    Regarding the sockets. In my case this is a problem. It causes OPC server to stop working after a while
    I have to use polling instead of subscription to workaround this problem.
    But there is another problem.
    My opc client is stuck in reconnecting to OPC server. I run Wireshark to trace communication and find that OPC server returns "commFault" state on GetStatus call.
    Can I can disable "GetStatus" method call or inject my own handler of "GetStatus" response?
    You informed me earlier that I couldn't disable "ServerStatusCheckPeriod" for OPC-XML protocol. Is it correct?
    By the way, dOPC client just ignores opc server state. So, it does not have such problem and opens only 1 socket in subscription communication mode.
    01 Oct 2019 06:47 #7781 by support
    In question 2 , I wanted to know not just the technology (OPC XML-DA), but also the vendor/model of the server, if possible, please.
    Additional question: Does this, in some scenario, happen with ALL items and consistently - that is, you cannot actually get any data from the server using subscriptions? Or only for some times? Or does it work for some time and then it starts issuing these errors? Or is it kind of random?
    Regarding the sockets: The nature of OPC XML-DA subscription is in separate HTTP requests being issued over time, and each of them may have its own connection (= open socket). They should, however, be closing after some time. That is, if the number of open sockets does not grow "over all limits", I do not see it as a problem.
    30 Sep 2019 14:42 #7774 by Andriy
    1. Yes
    2. OPC XML-DA
    3. I don't know. It is reproduced only when subscription is used.
    4. I will try to do it
    I've noticed another thing. ConnectivityExplorer opens a lot of tcp sockets when subscribtion mode is used. The OPC server is the same - OPC XML DA. Why?
    30 Sep 2019 12:18 #7773 by support
    1. Is this an exception contained within the event argument of the DataChange notification:
    2. Which target OPC server is this with?>
    3. Is there a way for us to reproduce it?
    4. Can you capture the network communication?
    30 Sep 2019 11:42 #7772 by Andriy
    I get an error from OPC XML-DA server after subscribing to opc items: "The item value from OPC NET API (Data Access) does not specify a timestamp."
    Can you explain what is wrong?
    Do you know to to fix it?
