Union Complex Data Type
05 Sep 2019 07:44 - 05 Sep 2019 07:45 #7706 by support
Replied by support on topic Union Complex Data Type
OPC UA does not use the term "union", but if what you mean is a StructuredType with "switch" fields, as described in OPC UA 1.04 spec Part 5, Annex E: OPC Binary Type Description System, then yes, QuickOPC should be able to decode it.
For more information, see
- www.opclabs.com/products/quickopc/extensions/opc-ua-complex-data
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...omplex%20Data%20Extension.html
Complex data in UA is, well, complex, so I suggest that you test it out with your particular server and cponfiguration first.
[I am assuming that the question does not directly related to Live Binding or Live Mapping models - which is the category you have put your post in; I am therefore moving the question to where it more appropriately belongs. If that's not correct, let me know.]
Last edit: 05 Sep 2019 07:45 by support.
04 Sep 2019 22:03 - 05 Sep 2019 07:45 #7701 by kriskazmar
Will QuickOPC-UA .NET be able to decode the data for the following array of structures, where the structure contains a union complex data type? The OPC UA server address space will define the Event, Alarm, Valve and Mode structures, and will define the union complex data type per Part 6 of the OPC UA specification.
structure Event { UInt32 SwitchValue; union { structure Alarm; structure Valve; structure Mode; } Union; UInt32 EventId; DateTime EventDateTime; }; array Event Events[500];
Last edit: 05 Sep 2019 07:45 by support. Reason: added formatting
