OPC DA and Docker
17 May 2019 14:28 #7389 by support
Replied by support on topic OPC DA and Docker
In principle, there is no difference in what's supported between the "full" OS, or Docker.
OPC DA / OPC A&E would only be possible in Windows container. In Linux, OPC XML-DA and OPC UA are possible, because the only available .NET runtime is .NET Core. See opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...l#Development%20Platforms.html .
We have customers using our software in Docker, however it is not something we normally test. Recently somebody here reported intermittent network issues under Docker, for which there is yet no resolution (but others have not had this issue). So, you need to test it out well upfront, to be sure that it works for you.
The following user(s) said Thank You: davide
17 May 2019 14:21 #7388 by davide
OPC DA and Docker was created by davide
Good Morning,
I'm using successfully your lib in a net-framework app on a VM. I would know if it is possible to use it inside a docker container.
Thanks in advance,
Davide
