Problem with mapping arrays
03 Aug 2018 06:18 #6579 by support
Replied by support on topic Problem with mapping arrays
We will reply. Please wait.
02 Aug 2018 19:53 #6575 by ab
Hello
I have a problem with reading tables from the OPC UA server.
I do not know why, but if I use mapping objects, their vaules are always zeros after reading from opc.
If I read them directly, the values in the array are valid.
What am I doing wrong?
The following example illustrates the problem.
UAClientMapper mapper = new UAClientMapper(); TestArray device = new TestArray { BrowswerPath = "ObjectsFolder]/PLC1500/Device1/Program_blocks/UM01_przyklad/Data/UM01_PackTags" }; UANodeDescriptor uANodeDescriptor = new UANodeDescriptor { BrowsePath = UABrowsePath.Parse(device.BrowswerPath, "KEPServerEX") }; UAEndpointDescriptor uAEndpointDescriptor = new UAEndpointDescriptor("opc.tcp://127.0.0.1:49320"); var uaNodeElementCollection = mapper.Client.BrowseDataNodes(uAEndpointDescriptor); mapper.Map(device, new UAMappingContext { EndpointDescriptor = uAEndpointDescriptor, NodeDescriptor = uANodeDescriptor, MonitoringParameters = 1000 }); mapper.Read(); var easyUAClient = new EasyUAClient { Isolated = true }; var a = easyUAClient.Read(uAEndpointDescriptor, "nsu=KEPServerEX;ns=2;s=PLC1500.Device1.Program_blocks.UM01_przyklad.Data.UM01_PackTags.Admin.ModeCumulativeTime"); var b = device.ModeCumulativeTime; [UAType] [UANamespace("KEPServerEX")] public class TestArray : IBrowsePath { public TestArray() { ModeCumulativeTime = new long[6]; } [UAData] [UANode] public long[] ModeCumulativeTime { get; set; } public string BrowswerPath { get; set; } }
After executing the code, the values for the variable "a" are for example [1, 2, 3, 10, 100, 5] and for "b" it are always [0, 0.0,0,0,0], why? It's the same array in opc.
What should mapping look like if we have a two-dimensional array? Can I map an array of objects, for example: MyClass[];?
