Force MonitoredItem to Read/Update on demand (Should be Easy)
12 Jan 2018 10:36 #5856 by support
to my knowledge there is no "refresh" mechanism. You can use the "Read" as you mentioned, but if you experience blocking, use a second instance of EasyUAClient just for this Read, and set its "Isolated" property to 'true'.
11 Jan 2018 16:33 #5855 by dataman1
I currently add items to the EasyUAClient by using SubscribeMultipleMonitoredItems(). Everything works fine except I would like to periodically do a refresh on all of the values. I have tried doing a ReadMultiple() with all the same items, but the problem is that it will hang the uaclient until it is completed.
Is there any way to force the monitored items to refresh the values on demand? I wasn't sure if there was a parameter to change that would cause a refresh? I know I can do a unsubscribe/resubscribe to achieve want I want, but thought I would ask if there is another mechanism.
Thanks for all your help!
