Using await Task.Run
20 May 2017 13:30 #5170 by support
Replied by support on topic Using await Task.Run
Yes, doing so is safe.
19 May 2017 18:52 #5169 by hcvoort
Replied by hcvoort on topic Using await Task.Run
Oke, I will come back on this subject if I encounter issues. Another related question: Can one instance of the EasyUaClient be used by multiple threads at the same time, or do I have to lock the instance untill the instance method is finished?
18 May 2017 14:21 #5164 by support
This has not been tested, so I cannot really give you a positive or negative answer.
You need to try it yourself.
If you run into problems, report it here, and we will have a look at it.
18 May 2017 11:17 #5160 by hcvoort
Using await Task.Run was created by hcvoort
Dear Sir/Madam,
Is it possible to use
await Task.Run(()=>{EasyUAClient.XXXXX;}); together with an async method
or will this potentially cause a deadlock?
BR,
Carsten Voort
