An OPC operation failure with error code -1073430509 (0xC004C013) occurred
18 Jan 2017 17:08 #4789 by support
You are welcome.
It's good that it works now, but it is not normal. It probably indicates a problem in the server, OR a problem in the reverse direction of DCOM communication (callbacks from server to the client - those are needed for async methods, and subscriptions).
The following user(s) said Thank You: Jukka
18 Jan 2017 11:57 #4788 by Jukka
Hello
You are right, now its working.
The AllowAsynchronousMethod says in definition "When true, asynchronous OPC reads and writes will be allowed".
This is my misunderstanding about the method.
Thanks very much :)
Jukka
18 Jan 2017 11:05 #4787 by support
I do not quite understand why you cannot modify to async OPC calls. QuickOPC API for Reads/Writes is synchronous anyway, it transforms OPC async calls to look as synchronous already for you, and whether the OPC call is sync or async is (should be) irrelevant to what happens on the device side.
18 Jan 2017 08:48 #4784 by Jukka
Hello
I cannot modify my project because it need asynchronous write and read.
Only DAClient working with ABB.
Maybe we wait the response from ABB if there is something to do with license.
18 Jan 2017 07:35 #4781 by support
This could mean that the server has not returned the control from some OPC call.
Have you tried some other OPC client, and what were the results?
Can you modify your project and try to enforce synchronous reads (set client.InstanceParameters.Mode.AllowAsynchronousMethod = false;).
16 Jan 2017 07:32 #4758 by Jukka
1. The server is remote ABB.AfwOpcDaSurrogate.
2. Remote.
3. The reading is possible if the user is same in client and server-side.
But in this case the server is not starting a new service. It using the existing server ABB.AfwOpcDaSurrogate.
We have created new user in client side and server side. A new server process is starting ABB.AfwOpcDaSurrogate.1 but the reading giving the error.
4. It happend always.
5. Half an hour.
6. Version QuickOPC 5.4.
I've also done a survey on ABB.
T:Jukka
14 Jan 2017 16:00 #4757 by support
can you please answer following questions?
1. Is the server on the same machine as client, or is it remote?
2. (if local) Do you know whether it is in in-process server (essentially a DLL that runs inside the client's process), or out of process (runs in a separate process)?
3. Are you ever able to read, or does it happen just sometimes?
4. If it happens just sometimes, is there an indication that it could be caused by problems on the server side, or in a communication (network)?
5. If you are doing further reads, do they - after some time - start working correctly , or is it so that after receiving this error, they never resume ? (if so, how long have you waited)?
6. If you are receiving this error for longer time, and during that time try to connect to the same server using a separate instance of the client, do you also get the same error, or does the 2nd instance of the client work well?
7. Which version of QuickOPC are you using?
12 Jan 2017 11:41 #4747 by Jukka
Hello
This kind of problem come with ABB.AfwOpcDaSurrogate.1 - server.
Any ideas how to solve it ?
ErrorTxt:
2017-01-12 10:57:29 OpcLabs.EasyOpc.OperationModel.OpcException: An OPC operation failure with error code -1073430509 (0xC004C013) occurred, originating from 'OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient'. The inner exception contains details about the problem. ---> System.Runtime.InteropServices.COMException: Read not completed. This error indicates that it could not be verified that the requested read operation was completed during the timeout period. It is possible that the read operation will actually succeed or fail, but later. Increase the timeout period if you want to obtain positive or negative indication of the operation outcome. Other reason for this error may be that under heavy loads, topic request or response queue is overflowing. Check the event log for queue overflow errors (if event logging is supported by the product and enabled).
at OpcLabs.EasyOpc.EasyUtilities.CheckSuccess(OperationResult operationResult)
at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.ReadItem(IEasyDAClient client, ServerDescriptor serverDescriptor, DAItemDescriptor itemDescriptor, DAReadParameters readParameters)
at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.ReadItem(IEasyDAClient client, ServerDescriptor serverDescriptor, DAItemDescriptor itemDescriptor)
at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.ReadItem(IEasyDAClient client, String machineName, String serverClass, String itemId, VarType dataType)
at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.ReadItem(IEasyDAClient client, String machineName, String serverClass, String itemId)
at EasyOpcNetDemo.MainForm.AloitaMallinnus_Click(Object sender, EventArgs e) in c:\Omat\Tyotw\Sin3PyrometriMallinnus\OPCToMysql_3\MainForm.cs:line 181
T: Jukka Kuikka
