Correct way of handling easyUAClient.MonitoredItemChanged
19 Oct 2016 11:42 #4480 by support
I do not have an example at hand, but I think that using the ThreadPool.QueueUserWorkItem Method (WaitCallback, Object) for this would be easy ( msdn.microsoft.com/en-us/library/4yd16hza(v=vs.110).aspx - with an example, too).
19 Oct 2016 06:52 #4478 by andis59
We have a program that makes a SubscribeMultipleMonitoredItems for a number (5) fields/tags with the event handler easyUAClient.MonitoredItemChanged += easyUAClient_MonitoredItemChanged;
In easyUAClient_MonitoredItemChanged, after checking that there is no exception, we check which tag that has given the event.
For each tag we save the value in a property and send the same value back to the PLC.
I found a note in one of the topics that is was not a good idea to call operations on EasyUAClient from inside an event handler. You recommend a queue that is processed in an another thread.
Would you please give an sample of how this would look like in C#.
We have all sorts of "strange" errors that maybe is caused by this...
