Example needed - subscribe to OPC item change event
18 Oct 2016 06:07 #4474 by den Bekker
Thank you,
This will put mme on track I think.
Ruud
17 Oct 2016 14:08 #4473 by support
The simplest (although not very realistic) example is on our Web page: www.opclabs.com/products/quickopc/languages-and-tools/csharp .
Better examples: open the solution with C# Examples (from the Start menu), then look into the Console/DocExamples project. You will find there e.g. following examples:
1.
// This example shows how subscribe to changes of multiple items and display the value of the item with each change, // using a callback method specified using lambda expression. using System.Diagnostics; using OpcLabs.EasyOpc.DataAccess; using System; using System.Threading; namespace DocExamples { namespace _EasyDAClient { class SubscribeItem { public static void CallbackLambda() { // Instantiate the client object var easyDAClient = new EasyDAClient(); Console.WriteLine("Subscribing..."); // The callback is a lambda expression the displays the value easyDAClient.SubscribeItem("", "OPCLabs.KitServer.2", "Simulation.Random", 1000, (sender, eventArgs) => { Debug.Assert(eventArgs != null); if (eventArgs.Exception != null) Console.WriteLine(eventArgs.Exception.ToString()); else { Debug.Assert(eventArgs.Vtq != null); Console.WriteLine(eventArgs.Vtq.ToString()); } }); Console.WriteLine("Processing item changed events for 10 seconds..."); Thread.Sleep(10 * 1000); Console.WriteLine("Unsubscribing..."); easyDAClient.UnsubscribeAllItems(); Console.WriteLine("Waiting for 2 seconds..."); Thread.Sleep(2 * 1000); } } } }
2.
// This example shows how subscribe to changes of multiple items and display the value of the item with each change. using JetBrains.Annotations; using OpcLabs.EasyOpc.DataAccess; using OpcLabs.EasyOpc.DataAccess.OperationModel; using System; using System.Threading; namespace DocExamples { namespace _EasyDAClient { partial class SubscribeMultipleItems { public static void Main() { using (var easyDAClient = new EasyDAClient()) { easyDAClient.ItemChanged += easyDAClient_ItemChanged; easyDAClient.SubscribeMultipleItems( new[] { new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Random", 1000, null), new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Ramp (1 min)", 1000, null), new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Trends.Sine (1 min)", 1000, null), new DAItemGroupArguments("", "OPCLabs.KitServer.2", "Simulation.Register_I4", 1000, null) }); Console.WriteLine("Processing item changed events for 1 minute..."); Thread.Sleep(60 * 1000); } } // Item changed event handler static void easyDAClient_ItemChanged([NotNull] object sender, [NotNull] EasyDAItemChangedEventArgs e) { Console.WriteLine("{0}: {1}", e.Arguments.ItemDescriptor.ItemId, e.Vtq); } } } }
If you are more interested in code in some more specialized environment (such as Windows Forms - showing data as values of texboxes etc.), we have such examples as well - let me know.
17 Oct 2016 13:50 #4472 by den Bekker
1) OPC Data Access
2) C#
Ruud
17 Oct 2016 13:31 #4471 by support
Please indicate
1) which OPC specification do you intend to use (OPC Data Access, or OPC Unified Architecture) - the principle is the same, but the actual example code differs somewhat,
2) which programming tool/language do you intend to use/prefer.
17 Oct 2016 13:30 #4470 by support
Sent: Monday, October 17, 2016 2:12 PM
To: Z.
Subject: ...
Which example shows me how to subscribe to change events of
the OPC item?
I can read the item when loading a form, but of course I want to update
the data the moment it changes on the PLC.
R.
