Nuget package changelog
14 Aug 2016 07:26 #4295 by support
Replied by support on topic Nuget package changelog
Here are the fixes between 5.40.287.1 and 5.40.315.1:
21574 FIX: EnumeratedBrowseable.HasChildren (swapped parentHasBranches and parentHasLeaves), this bug caused malfunction of PointEditor with CompositeConnectivity
21563 FIX: failed preconditions (false positives) in UA Read/Write/CallMultipleXXXX when two or more sessions were addressed + added code comments
21554 FIX: ObjectDisposedException when EasyUAClient.AdaptableParameters.SessionParameters.CheckEndpointDomain = true (and UI enabled)
03 Aug 2016 20:31 #4289 by support
We currently publish all larger changes (between versions) in the What's New document, but we do not have a system for routinely publishing the changes between builds of the same version. Note that we never add or remove functionality with such new builds - there are only bug fixes there (and sometimes added examples).
You are right that it would beneficial to have access to such changelog. Definitely something we need to work on. We have the necessary info in the source control system but need to figure out how to routinely publishould it.
Due to a vacation time I cannot give you the details of the changes right noway, but can do so around August 14th. Out of my head, the bug fixes were related to OPC UA reliability, and Live Binding.
03 Aug 2016 14:22 #4288 by UKPR
Nuget package changelog was created by UKPR
do You provide a build to build changelog ? We are using Nuget package version 5.40.287 and the newest version is 5.40.315. Is the change log between versions 5.40.x published ? It would be beneficial to us to have such an information as it would help us decide if we need to upgrade to the newest version of the package.
Kind Regards,
Mike
Kind regards,
Software Engineer Team
UK Power Reserve Ltd
6th Floor, Radcliffe House, Blenheim Court, Solihull, B91 2AA.
