Need help on WriteMultipleItems or WriteMultipleItemValues in VB.NET
28 Jul 2016 07:49 #4284 by Sandro@More
27 Jul 2016 14:54 #4277 by support
The code for subscription is OK in general.
Here is an example for WriteMultipleItemValues:
' This example shows how to write values into multiple items. Imports OpcLabs.BaseLib.OperationModel Imports OpcLabs.EasyOpc.DataAccess Imports OpcLabs.EasyOpc.DataAccess.OperationModel Namespace _EasyDAClient Friend Class WriteMultipleItemValues Public Shared Sub Main() Dim easyDAClient = New EasyDAClient() Dim argumentsArray = New DAItemValueArguments() { _ New DAItemValueArguments("", "OPCLabs.KitServer.2", "Simulation.Register_I4", 12345), _ New DAItemValueArguments("", "OPCLabs.KitServer.2", "Simulation.Register_BOOL", True), _ New DAItemValueArguments("", "OPCLabs.KitServer.2", "Simulation.Register_R4", 123.45) _ } Dim resultsArray As OperationResult() = easyDAClient.WriteMultipleItemValues(argumentsArray) For i = 0 To resultsArray.Length - 1 Debug.Assert(resultsArray(i) IsNot Nothing) Console.WriteLine("resultsArray[{0}].Succeeded: {1}", i, resultsArray(i).Succeeded) Next i End Sub End Class End Namespace
Let me know if you need further help.
27 Jul 2016 14:26 #4276 by Sandro@More
It would be great if you can show me how exactly to do this based on my code.
In your opinion the code I wrote for reading the tags is valid or there are others solutions ?
Sandro
27 Jul 2016 14:20 #4275 by support
Calling WriteMultipleItemValues is similar to SubscribeMultipleItems, in that you need to prepare an array of argument objects upfront, and then make a single call. What exactly isn't clear about it?
If we provide an example with WriteMultipleItemValues (and talking to our simulation server, for verification), would that help ?
27 Jul 2016 13:38 - 27 Jul 2016 14:16 #4274 by Sandro@More
Hi guys,
I have not found any solution on my problem in the forum so please I need some help.
I wroted a VB.NET 2015 program that read from PLC (for debugging I use MATRIKONOPC Simulator) using SubscribeMultipleItems
and receiving data with the event EasyDAClient.ItemChanged and this works well (for the moment).
It's clear also how to write a single item but it is too slow to use this for my project.
What I need is a example on how to use WriteMultipleItems and WriteMultipleItemValues based on my program.
I want to send all the DTPWC_OPCItemIDs() with the relative tag value faster than possible.
Any idea ?
'.. sOPCServerNode = "127.0.0.1" sOPCServerName = "Matrikon.OPC.Simulation.1" sOPCAccessPath = "MorePlc.ENB.BACKPLANE.LOGIX5000" ' items to read from PLC DFPWS_ItemCount = 5 DFPWS_OPCItemIDs(1) = sOPCAccessPath & "." & "PSF_WS_MORE_PLC_WDOG_CNT" DFPWS_OPCItemIDs(2) = sOPCAccessPath & "." & "PSF_WS_PWRON" DFPWS_OPCItemIDs(3) = sOPCAccessPath & "." & "PSF_WS_STA" DFPWS_OPCItemIDs(4) = sOPCAccessPath & "." & "PSF_WS_ACT_BCK" DFPWS_OPCItemIDs(5) = sOPCAccessPath & "." & "PSF_WS_ACT_HEAT" ' ' items to write from PLC DFPWS_ItemCount = 3 DTPWC_OPCItemIDs(1) = sOPCAccessPath & "." & "PSF_WC_WDOG" DTPWC_OPCItemIDs(2) = sOPCAccessPath & "." & "PSF_WC_SETP_TRIG" DTPWC_OPCItemIDs(3) = sOPCAccessPath & "." & "PSF_WC_CNT_RST" ' tbDFPWC_OPCItemIDs_1.Text = "0" tbDFPWC_OPCItemIDs_2.Text = "0" tbDFPWC_OPCItemIDs_3.Text = "0" '.. EasyDAClient.UnsubscribeAllItems() ' Dim DFPWS_TagList = New List(Of DAItemGroupArguments)() For iDataFromPLC = 1 To DFPWS_ItemCount DFPWS_TagList.Add(New DAItemGroupArguments(sOPCServerNode, sOPCServerName,DFPWS_OPCItemIDs(iDataFromPLC), 100, "")) Next EasyDAClient.SubscribeMultipleItems(DFPWS_TagList.ToArray()) Public Sub UpdateTags(ByVal sender As Object, ByVal e As EasyDAItemChangedEventArgs) Handles EasyDAClient.ItemChanged Dim ItemValue Try If e.Vtq.Quality = 192 Then If e.Vtq Is Nothing Then ItemValue = "0" Else ItemValue = e.Vtq.DisplayValue() ' Select Case e.Arguments.ItemDescriptor.ItemId Case DFPWS_OPCItemIDs(1) : tbDFPWS_OPCItemIDs_1.Text = ItemValue Case DFPWS_OPCItemIDs(2) : tbDFPWS_OPCItemIDs_2.Text = ItemValue Case DFPWS_OPCItemIDs(3) : tbDFPWS_OPCItemIDs_3.Text = ItemValue Case DFPWS_OPCItemIDs(4) : tbDFPWS_OPCItemIDs_4.Text = ItemValue Case DFPWS_OPCItemIDs(5) : tbDFPWS_OPCItemIDs_5.Text = ItemValue End Select End If Catch DisplayException(e.Exception) End Try End Sub Private Sub btDFPWC_OPCItemIDs_1_Click(sender As Object, e As EventArgs) Handles btDFPWC_OPCItemIDs_1.Click EasyDAClient.WriteItemValue(sOPCServerNode, sOPCServerName, DTPWC_OPCItemIDs(1), tbDFPWC_OPCItemIDs_1.Text) End Sub Private Sub btDFPWC_OPCItemIDs_2_Click(sender As Object, e As EventArgs) Handles btDFPWC_OPCItemIDs_2.Click EasyDAClient.WriteItemValue(sOPCServerNode, sOPCServerName, DTPWC_OPCItemIDs(2), tbDFPWC_OPCItemIDs_2.Text) End Sub '..
Last edit: 27 Jul 2016 14:16 by support. Reason: code formatting
