- Thank you received: 0
BadSecureChannelClosed - error
I've found it
Kind regards,
Software Engineer Team
UK Power Reserve Ltd
6th Floor, Radcliffe House, Blenheim Court, Solihull, B91 2AA.
If you have a code that does not compile, please post it here...
Code:EasyUAClient.AdaptableParameters.Session.HoldPeriod = 60*1000;
which using should I include in order to get AdaptableParameters?
Kind regards,
I will use you advice and try with longer holdPeriod and then check if it helped.
Kind regards,
But, I have a suggestion: If you are just doing periodic reads and no subscriptions, increase the hold period, i.e. the period for which the QuickOPC (EasyUAClient) keeps the connection to the server open after use. The default is fairly short (5000 milliseconds = 5 seconds), therefore if you are initiating a read every 10 seconds, it is likely that the connection is getting closed (always or sometimes) in between the reads. That is quite inefficient anyway.
Assuming that you are *not* setting the Isolated property of EasyUAClient to 'true', try this - before making any OPC operations:
It will increase the hold period to 1 minute, and the connectin should therefore stay open all the time you are doing the periodic reads.
Kind regards,
?check the diagnostics on the server side, if possible.
I am getting following error:
My app is simple UA client reading manually 1 value from OPC Server. I need to read the value exactly e.g. 10sec. (I know that there is better option with subscription - upgrade of the app in progress)
After random time - sometimes 1day sometimes one week or few hours after rebooting of the app (running as a service) I am starting to get this error.
What could be possible causes? There is no security right now between client and the server. Server is KepServerEX5.18
Mateusz Siatrak
Kind regards,
