Problem with live mapping
  • miron
04 Mar 2015 17:13 - 04 Mar 2015 17:14 #2904 by miron
Replied by miron on topic Problem with live mapping
Currently I am using: KepSerwer V5.16.728.0
I attached two files:
1. Is KepSerwer project. You you could ope and load this project (I changed extension to txt)
2. csv file with list of tags.
In this case you need create memory channel: "common2OpcModel"
and driver: "msarna"
and import tags.
Last edit: 04 Mar 2015 17:14 by miron.
04 Mar 2015 16:57 #2903 by support
Replied by support on topic Problem with live mapping
Can you provide the server configuration so that I can actually try to reproduce it?
  • miron
04 Mar 2015 15:41 - 04 Mar 2015 15:54 #2902 by miron
No, unfortunately it did not help.
I have attached linqpad file with test.
In OPC this tag is defined as dword.
Last edit: 04 Mar 2015 15:54 by miron.
04 Mar 2015 15:31 #2901 by support
Please try changing the type of the Value property from 'uint' to Int64, so that it becomes CLS-compliant ( msdn.microsoft.com/en-us/library/12a7a7h3.aspx ).
  • miron
04 Mar 2015 15:11 - 04 Mar 2015 15:12 #2900 by miron
And I added pice of code:
td.LoadZonePosition.RwTestData.Value = 9001; mp.WriteTarget(td.LoadZonePosition.RwTestData,true); Thread.Sleep(1000); td.LoadZonePosition.RwTestData.Value = 0; mp.ReadTarget(td.LoadZonePosition.RwTestData,true);
Writing is working but Reading by using mapping is not working.
Could you help me?
Last edit: 04 Mar 2015 15:12 by miron.
  • miron
04 Mar 2015 11:54 - 04 Mar 2015 13:19 #2899 by miron
Problem with live mapping was created by miron
Hi, I have problem with live mapping.
It looks that read write is working and
also subscribing by EasyDAClient but live mapping is not working.
I have provided example and logs.
I have tested for two KepSerwer drivers:
1. Memory Driver (it works normal - without problems with crating own copy of data for each group with update rating)
2. TCP Simens (with connection with PLC)
log
In log you could see: "[Mapped thread] LoadZonePositio : 0 " value is not replicated
but normal subscription is working:
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 2 {System.Int64} @2015-03-04 11:36:39; Good
And it looks that mapping was done:
1: [Mapped thread] NodeDescriptor.BrowsePath=/common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition
(from NodeDescriptor)
2: [Mapped thread] Exception=null
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 0
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 24 {System.Int64} @2015-03-04 11:36:33; Good GoodNonspecific LimitOk (192)
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 0 {System.Int64} @2015-03-04 11:36:34; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=0 {System.Int64} @2015-03-04 11:36:35; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 1
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 1 {System.Int64} @2015-03-04 11:36:36; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=1 {System.Int64} @2015-03-04 11:36:37; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 2
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 2 {System.Int64} @2015-03-04 11:36:39; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=2 {System.Int64} @2015-03-04 11:36:39; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 3
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 3 {System.Int64} @2015-03-04 11:36:41; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=3 {System.Int64} @2015-03-04 11:36:41; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 4
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 4 {System.Int64} @2015-03-04 11:36:43; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=4 {System.Int64} @2015-03-04 11:36:44; Good GoodNonspecific LimitOk (192)
[TestReadWrite] Test for: /common2OpcModel/msarna/L1/Z1/ZonesCtx/LoadZonePosition, isolated: True, value: 5
[Subscribed event] LoadZonePositio : {Isolated=False}[12585986] 5 {System.Int64} @2015-03-04 11:36:45; Good GoodNonspecific LimitOk (192)
[TestReadWrite] ValueAfterRead=5 {System.Int64} @2015-03-04 11:36:46; Good GoodNonspecific LimitOk (192)
code
void Main() { var root = "/common2OpcModel"; TestData td = new TestData(); var mp = new DAClientMapper(); var d = new DAMappingContext() { ServerDescriptor = Test.cServer, // local OPC server NodeDescriptor = new DANodeDescriptor { BrowsePath = root + "/msarna/L1/Z1/ZonesCtx"}, GroupParameters = 300, }; mp.Map(td, d); mp.Client.SubscribeItem(Test.cServer, new DAItemDescriptor() { BrowsePath= root + "/msarna/L1/Z1/ZonesCtx/LoadZonePosition"}, 300,(e1,e2)=> { Console.WriteLine("[Subscribed event] LoadZonePositio : " + e1.ToString() + e2.ToString()); },null); mp.Subscribe(true); uint val = 0; var t1 = new Thread(()=>{ while(true) { Test.TestReadWrite(root +"/msarna/L1/Z1/ZonesCtx", "LoadZonePosition", val, true); // or writing by rw mapping //td.LoadZonePosition.RwTestData.Value = val; //mp.WriteTarget(td.LoadZonePosition.RwTestData,false); Thread.Sleep(1500); val++; if(val >40) { val =0; } } }); var t2 = new Thread(()=> { Thread.Sleep(1000); Console.WriteLine("[Mapped thread] NodeDescriptor.BrowsePath=" + td.LoadZonePosition.CvTestData.NodeDescriptor.BrowsePath.ToString() ); Console.WriteLine("*************************************************"); while(true) { Console.WriteLine("[Mapped thread] LoadZonePositio : " + td.LoadZonePosition.CvTestData.Value ); if (td.LoadZonePosition.CvTestData.Exception != null) { Console.WriteLine("[Mapped thread] Exception=" + td.LoadZonePosition.CvTestData.Exception.Message); } else { Console.WriteLine("[Mapped thread] Exception=null"); } Thread.Sleep(1500); } }); t1.Start(); t2.Start(); t1.Join(); t2.Join(); } [DAType] public class TestData { public TestData() { LoadZonePosition = new CvRwBoxTestData(); } [DANode()] public CvRwBoxTestData LoadZonePosition {get;set;} } [DAType] public class CvRwBoxTestData { public CvRwBoxTestData() { //I have commented RW value mapping //RwTestData = new RwTestData(); CvTestData = new CvTestData(); } // [DANode(BrowsePath = "")] // public RwTestData RwTestData {get;set;} [DANode(BrowsePath = "")] public CvTestData CvTestData {get;set;} } /* [DAType] public class RwTestData { [DANode(BrowsePath = "")] [DAItem(Operations = DAItemMappingOperations.Subscribe)] [DARead(DataSource = DADataSource.Device)] public uint Value {get;set;} [DANode(BrowsePath = "")] [DAItem(Kind = DAItemMappingKind.Exception, Operations=DAItemMappingOperations.ReadAndSubscribe)] [DARead(DataSource = DADataSource.Device)] public Exception Exception {get;set;} [MetaMember("NodeDescriptor")] public NodeDescriptor NodeDescriptor { get; set; } }*/ [DAType] public class CvTestData { [DANode(BrowsePath = "")] [DAItem(Operations = DAItemMappingOperations.ReadAndWrite)] public uint Value {get;set;} [DANode(BrowsePath = "")] [DAItem(Kind = DAItemMappingKind.Exception, Operations=DAItemMappingOperations.ReadAndWrite)] public Exception Exception {get;set;} [MetaMember("NodeDescriptor")] public NodeDescriptor NodeDescriptor { get; set; } } class Test { public const string cServer = "Kepware.KEPServerEX.V5"; public static void TestReadWrite(string rootPath, string valName, object value, bool isolated) { string path = rootPath + "/" + valName; Console.WriteLine("[TestReadWrite] Test for: " + path + ", isolated: " + isolated.ToString() + ", value: " + value.ToString()); EasyDAClient c1 = new EasyDAClient(); EasyDAClient c2 = new EasyDAClient(); c1.Isolated = isolated; c2.Isolated = isolated; c1.WriteItemValue(new ServerDescriptor (){ ServerClass = cServer}, new DAItemDescriptor() { BrowsePath= path},value); Thread.Sleep(1000); var ds = new DAItemDescriptor() { BrowsePath= path}; if (value is bool) ds.RequestedDataType = VarType.Bool; var valB = c2.ReadItem( new ServerDescriptor (){ ServerClass = cServer}, ds , new DAReadParameters(){ DataSource= DADataSource.Device, } ); Console.WriteLine("[TestReadWrite] ValueAfterRead=" + valB.ToString()); } }
Last edit: 04 Mar 2015 13:19 by miron.
