Windows Service with WCf
09 Dec 2014 09:52 #2555 by support
Replied by support on topic Windows Service with WCf
We do not have an out-of-box example for the combination you described.
As a proof of feasibility, in the examples solution for C# and VB.NET, we have a very simple WCF service project (called Web\WcfService1), and a client to it (called Console\WcfClient1).
The service contract:
using System.ServiceModel; namespace WcfService1 { // NOTE: If you change the interface name "IService1" here, you must also update the reference to "IService1" in Web.config. [ServiceContract] public interface IService1 { [OperationContract] string GetData(); } }
The service implementation:
// WcfService1: A simple Web service using WCF technology. Provides a GetData method to read a value of an OPC item. // Use WcfClient1 project (under Console folder) to test this Web service. using OpcLabs.EasyOpc.DataAccess; namespace WcfService1 { // NOTE: If you change the class name "Service1" here, you must also update the reference to "Service1" in Web.config and in the associated .svc file. public class Service1 : IService1 { public string GetData() { var easyDAClient = new EasyDAClient(); object value = easyDAClient.ReadItemValue("", "OPCLabs.KitServer.2", "Demo.Ramp"); return (value == null) ? "" : value.ToString(); } } }
The client:
// WcfClient1: Using a Web service provided by the WcfService1 project (under Web folder), gets and displays a value of // an OPC item. using System; namespace WcfClient1 { class Program { static void Main() { var client = new Service1Client(); // Use the 'client' variable to call operations on the service. Console.WriteLine(client.GetData()); Console.ReadLine(); // Always close the client. client.Close(); } } }
What you described should be doable. If you run into any specific issues, let me know and we will try to help.
08 Dec 2014 20:15 #2552 by neilcooley
Hi
Do you have any examples of Windows Service communicating to a Windows Form using WCF?
I am thinking of something along these lines;
Windows Service, ItemChanged event, updates a list with real time values
Windows form via WCF, polls that list and displays the values in a listview.
Neil
