WriteItemValue -> "Exception from HRESULT: 0xC004D004"
Zbynek Zahradnik
- jorma.sarnikorpi@ontec.fi
Topic Author
- Offline
- New Member
- Thank you received: 0
Problem solved! It seems that problem was caused by FSGateway. I did update it to version 1.5 SP1 and after this I was able to write values without exceptions.
Topic Author
- Offline
- New Member
Best Regards,
Jorma
ZZ
Topic Author
- Offline
- New Member
I am using Wonderware FSGateway 1.5. I couldn't find any decent documentation to its error codes. But I found following entries from log of FSGateway:
Timed out waiting for CAL to return Poke acknowledgement for item
Item 'ai_H_LTE_SP_7' poke failed [hr=c004d004]
So, I guess you are right; error comes from OPC Server.
What is the OPC server you are using?
Is there any documentation to its error code?
Many thanks
Zbynek Zahradnik
Topic Author
- Offline
- New Member
I am using method WriteItemValue(). It takes something like 30 seconds and then there comes out exception "Exception from HRESULT: 0xC004D004". Interesting thing is that value _is_ written into the item (I can see its value changing).
I can also read corresponding item without problems using ReadItem().
Any ideas what is going on?
