Changing property name in Live Mapping
10 Mar 2014 13:48 - 10 Mar 2014 16:35 #1763 by support
If I understand it correctly, all you want to do at this point is to change the name of the property in C#, while the physical Item ID in the OPC Server remains the same. I.e. the C# property would be named "Outputs", while the OPC ItemID still ends with ".Output".
To do this, it should be sufficient to provide the (last element of) BrowsePath, as you have already done. The code would look like this:
// Boilers.Boiler #1.Drum1001.LIX001.Output //Item ID path [DANode(BrowsePath = "Output")] [DAItem] public virtual double Outputs { get { return this._output; } set { this._output = value; this.Notify("Output"); } }
The AccessPath is not the right thing to use. AccessPath is a rarely used additional info to the OPC Server (very few servers actually use it), to specify HOW the item should be accessed. If you really wanted to specify the "Boilers.Boiler #1.Drum1001.LIX001.Output", you would use the ItemId named argument of the DANode attribute.
Please let me know if the suggested code works. If not, please specify precisely which version/build of QuickOPC you are testing with, as some builds did have a bug in this area.
Last edit: 10 Mar 2014 16:35 by support. Reason: added missing [DAItem]
10 Mar 2014 13:38 - 10 Mar 2014 13:38 #1762 by support
Sent: Monday, March 10, 2014 1:30 PM
Subject: OPC DAClient Access
{translated}
This works for me:
// Boilers.Boiler #1.Drum1001.LIX001.Output – ItemID [DANode()] [DAItem()] public virtual double Output { get { return this._output; } set { this._output = value; this.Notify("Output"); } }
I have changed the name of the property to Output ->Outputs (resp. I do not want to have special characters, spaces, ... in the name of the variable)
// Boilers.Boiler #1.Drum1001.LIX001.Output //Item ID path [DANode(BrowsePath = "Output")] [DAItem(AccessPath = "Boilers.Boiler #1.Drum1001.LIX001.Output")] - does this have to be entered? If so, how? public virtual double Outputs { get { return this._output; } set { this._output = value; this.Notify("Output"); } }
Last edit: 10 Mar 2014 13:38 by support.
