Deployment without License install
03 Nov 2015 11:19 #3639 by sebpinski
Could you please edit the URL as it just takes me to the restricted page (when signed in). I cannot find the article in the knowledge base.
03 Nov 2015 09:52 #3638 by support
I have identified you by the domain in your email address, and enabled your account to access the document. Please access
www.quickopc.com/resources/product-information/knowledge-base/category/35-restricted
while begin logged to this site.
03 Nov 2015 09:37 #3637 by sebpinski
Dear Support,
I'd like the information on deployment without using the license manager but the site license was purchased under an account created by someone in our purchasing department. Could you please let me know how I can get hold of the documentation with instruction on how to do this without having to contact the purchasing department.
I can provide a copy of our invoice for the site license if necessary.
Sebastian
29 Mar 2013 20:51 #1263 by support
You are not deploying Microsoft.Contracts.dll to the target computer. It is necessary that this assembly is available to the application, either from file system or from the GAC.
The following user(s) said Thank You: arahming
29 Mar 2013 15:07 #1262 by arahming
I am confused by the question this program is designed not to be installed as I have specified due to NERC if we install this application on NERC restricted assets that it would become useless due to the change management and testing process.... I have dropped pretty much all your assemblies in the applications folder, I have also used dependancy walker and added a bunch of *.dll they said where needed but it still does not work... I am almost 100% sure if you attemtp to run this application on a test XP or 2003 server it will not run until you install the QuickClient 5.21
File Name: Asssemblies.bmp
File Size:1,621 KB
29 Mar 2013 14:48 #1261 by support
Can you please send me a list of files, or a picture of the folder where your application is installed on the target computer. I'd like to check if all assemblies are present.
29 Mar 2013 14:42 #1260 by arahming
Here is the test project I created. it has the same exact issues as the real project when you click on the exe the win form will not open. once you install your program its fine tested on windows 2003 and XP we do not use 2008 for our older scada systems
File Name: TEST_WIN_FORM.zip
File Size:42 KB
29 Mar 2013 07:11 #1259 by support
Thank you. Can you please send me a list of files, or a picture of the folder where your application is installed on the target computer? I'd like to check if all assemblies are present.
28 Mar 2013 18:15 #1258 by arahming
I don't think the VS 2012 update 1 matters as I explained earlier everything works if I install the licesnes manager. the build is 5.21 101.1.
thanks
File Name: WithLicenseManger.bmp
File Size:1,998 KB
File Name: WithoutLM.bmp
File Size:1,236 KB
28 Mar 2013 17:48 #1257 by support
I have now enabled the BMP extension in the forums, please add your images.
I am still missing the build number. The first install page says "This will install OPCData.NET 5.21 Build XXX.X on your computer". I need the number after the Build word.
If the list at the bottom of your email is supposed to list the C++ runtimes, then you are missing the one for Visual Studio 2012 Update 1.
