WriteVQT
23 May 2012 11:12 #863 by support
Replied by support on topic Re: WriteVQT
In our product, "WriteVQT" is performed by EasyDAClient.WriteItem and EasyDAClient.WriteMultipleItems methods.
The "regular" writes (with just a value, no quality or timestamp) are performed by EasyDAClient.WriteItemValue and EasyDAClient.WriteMultpleItemValues methods.
Note that if you are using any of the .NET-based languages, you should rather use the QuickOPC.NET product. The methods are the same, just the parameters differ slightly.
Example (VBScript):
See IEasyDAClient.WriteItem.Main.vbs.
Rem+++
Rem This example shows how to write a value, timestamp and quality into a single item.
Option Explicit
Dim EasyDAClient: Set EasyDAClient = CreateObject("OPCLabs.EasyDAClient.5.1")
EasyDAClient.WriteItem "", "OPCLabs.KitServer.2", "Simulation.Register_I4", 12345, Now(), 192
Rem---
23 May 2012 09:46 #862 by mavhacii
WriteVQT was created by mavhacii
I need to access to OPC server 3.0, where I will be writing the "INPUT" and "OUTPUT" variables. I also will be writing the timestamp and quality for each object. Based on " www.opcfoundation.org/forum/viewtopic.php?p=12299 ", I have downloaded and tried, but could not find the "writeVQT" function. Kindly advice on how to do this. Our customer is using DNP3 OPC Server, so time is very crucial.
Time to create page: 0.150 seconds
