MultipleItemsChanged event in C++
12 Oct 2011 14:02 #532 by support
I am glad it's solved.
Here is the AE part - the dispids are 2001 and 2501.
object,
uuid(3FFF7D29-23DF-4050-9935-1BCB4E652D81),
oleautomation,
nonextensible,
helpstring("EasyAEClient Events"),
pointer_default(unique),
hidden
interface _IEasyAEClientEvents : IUnknown {
[id(2001), helpstring("Raised for every OPC event subscribed to by the SubscribeEvents method")]
HRESULT Notification([in] VARIANT varSender, [in] VARIANT varE);
[id(2501), helpstring("Raised for OPC events subscribed to by the SubscribeEvents method")]
HRESULT MultipleNotifications([in] VARIANT varSender, [in] VARIANT varEA); }
12 Oct 2011 14:01 #531 by support
Sent: Wednesday, October 12, 2011 2:50 PM
Hi, I have solved the problem. I missed some atl calls. But I also have to use AE, is the events handled in the same way?
If so what disp-ids do I need to get the events?
Now I am using 1002 for ItemChanged and 1004 for MultipleItemsChanged. What id do I need for AE?
J.
12 Oct 2011 14:00 #530 by support
Sent: Wednesday, October 12, 2011 9:46 AM
To: .....
I have made a test application that uses IDispEventImpl in order to get hold of the MultipleItemsChanged event, but I don’t get the event. Do you have any suggestions? I provide the code in the mail.
Is it possible to subscribe for 20.000 to 25.000 items using the SubscribeMultipleItems interface? Have you made any tests with that amount of items?
J.
[attached zip with unnecessary files removed]
12 Oct 2011 13:55 #528 by support
Yes, SubscribeMultipleItems is the best way.
I will look whether we have that example in C++.
12 Oct 2011 13:54 #527 by support
Sent: Tuesday, October 11, 2011 12:07 PM
Subject: ....
In the application that I will build using your toolkit, if I can get the right performance, we have to keep track of 20.000-25.000 opcitems. There will not be value changes on all items at the same time, but as I understand it a call to SubscribeMultipleItems with all items will work, and I will get the highest performance that way?
Do you have any example code on how to make the MultipleItemsChanged event work in C/C++? I can not figure out how to catch the events.....
<span style="font-family: "Calibri","sans-serif"; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">J.
