OPCDA subscription Cast Error in Delphi
15 Sep 2025 13:48 #14369 by wsalvin
Okay,
Thank you for your help.
I find the Issue,  the TLBs were not overrided.
Now it works, I will check if i still face memory leak.
And i will open another tread in case.
15 Sep 2025 09:52 #14368 by support
The I in angle brackets means "switch to italics" - this is BBCode, quite common in forums -  en.wikipedia.org/wiki/BBCode .
Enclose the entirety of your code in [code] instead.
I will rethink my answer and reply later.
15 Sep 2025 09:50 #14367 by wsalvin
I suspect the TLBs was not overrided. let me do it again. I keep you informed.
Thank
15 Sep 2025 09:24 #14366 by wsalvin
again the "I" disappear. see previous screen shot.
15 Sep 2025 09:22 #14365 by wsalvin
Oups sorry.
I just checked my code.see screen shot.
in my code it's Arguments := ItemSubscriptionArguments;
I do not know why when i copy past the code  the '' disappear.
regards
    15 Sep 2025 09:05 - 15 Sep 2025 09:05 #14364 by support
    In your code, you create the Arguments as an array, that's true. But then, inside the loop, you overwrite with just one element:
    I do not see how this can work.
    Last edit: 15 Sep 2025 09:05 by support.
    15 Sep 2025 08:56 #14363 by wsalvin
    My code is based on your exemple. the only diff is only that the number of requested Tag is a parameter and is include in a VCL app.
    I create an Array : Arguments := VarArrayCreate([0, NbTag - 1], varVariant); to pass to SubscribeMultipleItems.
    My code was working well on \OPC Labs QuickOPC 2020.2 except a memory leak.
    So I upgrade on 2025 in order to see if the memory leak is fixed. but i no more able to run my appli an i face the issue i sent you as screen shot on previous mail.
    To upgrade i installed the new 2025 release a regenerate TLB from SDK/Lib folder.
    When I run the application I checked the DLL loaded by my app and now its the 2025 one.
    Any idea of what else i can do?
    15 Sep 2025 08:29 #14362 by support
    Hello._EasyDAItemSubscriptionArguments is the right type for SubscribeMultipleItems. However, it has to be an *array* of them. Why don't you just base your code on the example provided for SubscribeMultipleItems? From opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...e%20to%20multiple%20items.html :
    // This example shows how to subscribe to changes of multiple items and display the value of the item with each change. // // Find all latest examples here: https://opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Latest/examples.html . // OPC client and subscriber examples in Object Pascal (Delphi) on GitHub: https://github.com/OPCLabs/Examples-QuickOPC-OP . // Missing some example? Ask us for it on our Online Forums, https://www.opclabs.com/forum/index ! You do not have to own // a commercial license in order to use Online Forums, and we reply to every post. type TSubscribeMultipleItems_ClientEventHandlers = class // Item changed event handler procedure OnItemChanged( ASender: TObject; sender: OleVariant; const eventArgs: _EasyDAItemChangedEventArgs); end; procedure TSubscribeMultipleItems_ClientEventHandlers.OnItemChanged( ASender: TObject; sender: OleVariant; const eventArgs: _EasyDAItemChangedEventArgs); begin if eventArgs.Succeeded then WriteLn(eventArgs.Arguments.ItemDescriptor.ItemId, ': ', eventArgs.Vtq.ToString) else WriteLn(eventArgs.Arguments.ItemDescriptor.ItemId, ' *** Failure: ', eventArgs.ErrorMessageBrief); end; class procedure SubscribeMultipleItems.Main; var Arguments: OleVariant; Client: TEasyDAClient; ClientEventHandlers: TSubscribeMultipleItems_ClientEventHandlers; HandleArray: OleVariant; ItemSubscriptionArguments1: _EasyDAItemSubscriptionArguments; ItemSubscriptionArguments2: _EasyDAItemSubscriptionArguments; ItemSubscriptionArguments3: _EasyDAItemSubscriptionArguments; ItemSubscriptionArguments4: _EasyDAItemSubscriptionArguments; begin ItemSubscriptionArguments1 := CoEasyDAItemSubscriptionArguments.Create; ItemSubscriptionArguments1.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; ItemSubscriptionArguments1.ItemDescriptor.ItemID := 'Simulation.Random'; ItemSubscriptionArguments1.GroupParameters.RequestedUpdateRate := 1000; ItemSubscriptionArguments2 := CoEasyDAItemSubscriptionArguments.Create; ItemSubscriptionArguments2.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; ItemSubscriptionArguments2.ItemDescriptor.ItemID := 'Trends.Ramp (1 min)'; ItemSubscriptionArguments2.GroupParameters.RequestedUpdateRate := 1000; ItemSubscriptionArguments3 := CoEasyDAItemSubscriptionArguments.Create; ItemSubscriptionArguments3.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; ItemSubscriptionArguments3.ItemDescriptor.ItemID := 'Trends.Sine (1 min)'; ItemSubscriptionArguments3.GroupParameters.RequestedUpdateRate := 1000; ItemSubscriptionArguments4 := CoEasyDAItemSubscriptionArguments.Create; ItemSubscriptionArguments4.ServerDescriptor.ServerClass := 'OPCLabs.KitServer.2'; ItemSubscriptionArguments4.ItemDescriptor.ItemID := 'Simulation.Register_I4'; ItemSubscriptionArguments4.GroupParameters.RequestedUpdateRate := 1000; Arguments := VarArrayCreate([0, 3], varVariant); Arguments[0] := ItemSubscriptionArguments1; Arguments[1] := ItemSubscriptionArguments2; Arguments[2] := ItemSubscriptionArguments3; Arguments[3] := ItemSubscriptionArguments4; // Instantiate the client object and hook events Client := TEasyDAClient.Create(nil); ClientEventHandlers := TSubscribeMultipleItems_ClientEventHandlers.Create; Client.OnItemChanged := ClientEventHandlers.OnItemChanged; TVarData(HandleArray).VType := varArray or varVariant; TVarData(HandleArray).VArray := PVarArray( Client.SubscribeMultipleItems(Arguments)); WriteLn('Processing item changed events for 1 minute...'); PumpSleep(60*1000); WriteLn('Unsubscribing...'); Client.UnsubscribeAllItems; WriteLn('Waiting for 5 seconds...'); PumpSleep(5*1000); WriteLn('Finished.'); VarClear(HandleArray); VarClear(Arguments); FreeAndNil(Client); FreeAndNil(ClientEventHandlers); end;
    15 Sep 2025 07:43 #14361 by wsalvin
    hello i'm doing the following test In Delphi 12 with the last release QuickOPC (2025.1) I just downloaded.
    procedure TForm3.btnAddOpcdaClick(Sender: TObject);
    var
      ItemSubscriptionArguments: _EasyDAItemSubscriptionArguments;
    //  ItemSubscriptionArguments: _DAReadItemArguments;
    //  ItemSubscriptionArguments: _DAItemGroupArguments;
      I: Integer;
    begin
      // exemple in kb.opclabs.com/Reference_counting_in_Delphi
      //https://opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Latest/User%27s%20Guide%20and%20Reference-OPC%20Studio/Examples%20-%20OPC%20Data%20Access%20-%20Subscribe%20to%20multiple%20items.html
    //  CoInitialize(nil);
      ClientEventHandlers := TClientEventHandlers.Create;
      ClientOPCDA := TEasyDAClient.Create(nil);
      ClientOPCDA.OnItemChanged := ClientEventHandlers.OnDataChangeNotification;
      //init tag requested
      for I := 0 to NbTag - 1 do
      begin
        ItemSubscriptionArguments := CoEasyDAItemSubscriptionArguments.Create;
    //    ItemSubscriptionArguments := CoDAReadItemArguments.Create;
    //    ItemSubscriptionArguments := CoDAItemGroupArguments.Create;
          //Nom du PC
        ItemSubscriptionArguments.ServerDescriptor.MachineName := 'localhost';
          //Nom du serveur OPC
        ItemSubscriptionArguments.ServerDescriptor.ServerClass := 'Kepware.KEPServerEX.V6';
          //Nom du tag OPC
        ItemSubscriptionArguments.ItemDescriptor.ItemID := 'Simulation Examples.Functions.Ramp' + (I + 1).ToString;
          //Delai de rafraichissement
        ItemSubscriptionArguments.GroupParameters.RequestedUpdateRate := 1000;
      end;
      ClientOPCDA.SubscribeMultipleItems(Arguments);
      btnAddOpcda.Enabled := False;
      btnRemOpcda.Enabled := True;
      CodeSite.send('OPCDA Added');
    end;
    I face the following Error.
    Impossible d'effectuer un cast d'un objet de type 'OpcLabs.EasyOPC.DataAccess.OperationModel.EasyDAItemSubscriptionArguments en type OpcLabs.EasyOPC.DataAccess.OperationModel.DaReadItemArguments.
    Is _EasyDAItemSubscriptionArguments the right type to use for the array to pass to SubscribeMultipleItems?
