License file- python Code
10 Feb 2025 06:35 #13388 by adaml@trunovate.com
09 Feb 2025 16:25 #13387 by support
Replied by support on topic License file- python Code
The documentation says "obtain the static Instance Field from the LicensingManagement Class, and call the RegisterFile Method". So, I think that instead of "LicensingManagement.RegisterFile", there should be "LicensingManagement.Instance.RegisterFile".
09 Feb 2025 13:22 #13386 by adaml@trunovate.com
Why is this error being thrown?
The Output:
(componentName, licenseId, filePath)
Void RegisterFile(System.String, System.String, System.String)
No method matches given arguments for LicensingManagement.RegisterFile: (<class 'str'>, <class 'str'>)
import inspect import clr clr.AddReference(r'C:\Program Files (x86)\OPC Labs\QuickOPC 5.3\Assemblies\OpcLabs.BaseLib.dll') from OpcLabs.BaseLib.ComponentModel import LicensingManagement def register_license(): try: ci_print(inspect.signature(LicensingManagement.RegisterFile)) ci_print(LicensingManagement.RegisterFile.__doc__) # Define the required parameters component_name = "QuickOPC" license_id = "Multipurpose" license_file_path = r"C:\Program Files\Python312\QuickOPC.Key.bin" # Register the license file LicensingManagement.RegisterFile(component_name, license_id, license_file_path) ci_print("License registered successfully.") except Exception as e: ci_print(f"Error registering license: {e}")
09 Feb 2025 08:58 #13385 by support
09 Feb 2025 08:01 #13383 by adaml@trunovate.com
How can I load and apply a license from a .bin file using Python?
This is my code:
import opclabs_quickopc from OpcLabs.EasyOpc.UA.Discovery import * from OpcLabs.EasyOpc.UA.Gds import * from OpcLabs.EasyOpc.UA.Engine import * from OpcLabs.EasyOpc.UA import * from OpcLabs.EasyOpc.UA.Application import * from OpcLabs.EasyOpc.UA.Application.Extensions import * from OpcLabs.EasyOpc.UA.Extensions import * from OpcLabs.EasyOpc.UA.OperationModel import * from OpcLabs.EasyOpc.UA import EasyUAClient, UAEndpointDescriptor, UANodeDescriptor, EasyUAClientCore from OpcLabs.EasyOpc.UA.Engine import UAEngineException from OpcLabs.EasyOpc.UA import UAServiceException def setup_client(opc_server_url): client = EasyUAClient() try: shared_parameters = client.SharedParameters engine_parameters = shared_parameters.EngineParameters certificate_acceptance_policy = engine_parameters.CertificateAcceptancePolicy certificate_acceptance_policy.TrustedEndpointUrlStrings.Add(opc_server_url) except Exception as ex: handleError(f'Client Setup Error for {opc_server_url}', ex) raise return client def readOpcUA(tags): results = [] try: EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationName = \ 'PlantSharpEdgeGateway' arranged_tags = arrange_tags_by_url(tags) for opc_server_url, server_info in arranged_tags.items(): try: ci_print(f"Processing OPC UA server: {opc_server_url}") user_name = server_info.get("OpcServerUserName") password = 'xxxxxxx' # Define which GDS we will work with. gdsEndpointDescriptor = UAEndpointDescriptor(opc_server_url) gdsEndpointDescriptor = UAEndpointDescriptorExtension.WithUserNameIdentity(gdsEndpointDescriptor, user_name, password) node_ids = [tag['TagAddress'] for tag in server_info['tags']] nodes = [UANodeDescriptor(node_id) for node_id in node_ids] time = str(datetime.now(tzlocal.get_localzone())) client = setup_client(opc_server_url) try: attributeDataResultArray = IEasyUAClientExtension.ReadMultiple(client, gdsEndpointDescriptor, nodes) except UAEngineException as ua_ex: handleError(f'OPC-UA Engine Error for {opc_server_url} - {user_name}', ua_ex) except UAServiceException as service_ex: handleError(f'OPC-UA Service Error for {opc_server_url} - {user_name}', service_ex) except Exception as ex: handleError(f'General Error during ReadMultiple for {opc_server_url} - {user_name}', ex) except Exception as ex: handleError(f'Error processing server {opc_server_url} - {user_name}', ex) return results except Exception as ex: handleError('Error in readOpcUA function', ex) return results
