Support Microsoft Access Program
24 Jan 2024 14:03 #12531 by support
This is a bug. Thank you for reporting it. It should be fixed now. Please download the current version QuickOPC 2023.2 from our Downloads page, reinstall it, and retest.
Verification: The Setup program should report itself as 5.72.1043.1 or later.
24 Jan 2024 06:21 - 24 Jan 2024 14:02 #12529 by kuchlerm
Dear Opclabs Support
Our license order number is: 199932. A copy of invoice you will find in the attachment.
We have developed an opc client application with ms access version (Micosoft OfficeProfessional Plus Version 1808 (Build 10406.2006). The application is working perfect with your program library. We are using Version QuickOPC 2023.2 “C:\Program Files (x86)\OPC Labs QuickOPC 2023.2\SDK\lib\OpcLabs.EasyOpcUA.tlb”.
If an Access instance has already been started before our Access instance with QuickOPC, our solution will no longer work.
This can be reproduced by starting an empty Access instance (without any content).
In the event display of the Windows operating system we find the following error message. We are at a complete loss as to why the program behaves like this. We suspect that it could be a license problem, but we don't understand why. We would be very grateful for any helpful tips on how to solve the problem.
Many thanks in advance for your efforts.
Martin Küchler
Excerpt event display Windows operating system: Anwendung: MSACCESS.EXE Frameworkversion: v4.0.30319 Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet. Ausnahmeinformationen: System.ArgumentException bei System.IO.Path.LegacyNormalizePath(System.String, Boolean, Int32, Boolean) bei System.IO.Path.GetFullPathInternal(System.String) bei System.IO.FileInfo.Init(System.String, Boolean) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.AppConfigSdkConfigurationProvider.GetFilePathFromAppConfigReplacement(System.String) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.AppConfigSdkConfigurationProvider.GetConfiguration(OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase, Opc.Ua.Configuration.ApplicationInstance, Opc.Ua.ApplicationConfiguration ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase.MakeSdkApplicationConfiguration(Opc.Ua.Configuration.ApplicationInstance, Opc.Ua.ApplicationConfiguration ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase.CreateSdkApplicationConfiguration(Opc.Ua.Configuration.ApplicationInstance, Opc.Ua.ApplicationConfiguration ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase.CreateSdkApplicationInstance(Opc.Ua.Configuration.ApplicationInstance ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase.MakeSdkApplicationInstance(Opc.Ua.Configuration.ApplicationInstance ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase.MakeEngineRecord(System.Object ByRef) bei OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.InternalConnect() bei OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.Connect() bei OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.InnerReadAttributes(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[], OpcLabs.EasyOpc.UA.Engine.EasyUAAdaptableParameters) bei OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.ReadAttributes(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[], OpcLabs.EasyOpc.UA.Engine.EasyUAAdaptableParameters) bei OpcLabs.BaseLib.Internal.DisposableObject.DisposeGuard[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Func`1<System.__Canon>, Boolean) bei OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.Implementation.ErrorTransformingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.Implementation.DataConvertingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.Optimization.Implementation.RequestMergingEasyUAClient.<ReadMultiple>b__2_0(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.BaseLib.OperationModel.Extensions.IReadOnlyListOfOperationArgumentsExtension.MergingPerform[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Collections.Generic.IReadOnlyList`1<System.__Canon>, System.Func`2<System.__Canon[],System.__Canon[]>) bei OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension.SwitchCase[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Collections.Generic.IReadOnlyList`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Collections.Generic.IEqualityComparer`1<System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IReadOnlyList`1<System.__Canon>,System.Collections.Generic.IEnumerable`1<System.__Canon>>) bei OpcLabs.EasyOpc.UA.Implementation.MultiplexingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.ReadMultiple(OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments[]) bei OpcLabs.EasyOpc.UA.EasyUAClientCore+<>c.<.cctor>b__112_0() bei OpcLabs.BaseLib.Internal.Once+<>c__DisplayClass0_0.<.ctor>b__0() bei System.Lazy`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].CreateValue() bei System.Lazy`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].LazyInitValue() bei OpcLabs.BaseLib.Internal.Lazy2`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].<Kick>b__4_0() bei System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) bei System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) bei System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) bei System.Threading.ThreadHelper.ThreadStart()
Last edit: 24 Jan 2024 14:02 by support.
