Reading values with OpcLabs.BaseLib.Collections.ElasticVector
15 Sep 2023 09:38 #12145 by support
OK, thanks for letting me know! I was just about to work on your issue. But it would be painful to resolve - such problems, though trivial, are the worst ones to find...
15 Sep 2023 09:35 #12143 by info@software2000.it
I solved it, it was an oversight on my part, unfortunately the Nodeid contained a space at the end that was not visible!!!
15 Sep 2023 07:53 - 15 Sep 2023 07:54 #12140 by info@software2000.it
Good morning,
I'm using VisualFoxpro code to read values ​​from an OPC-UA server, I use the same code successfully in other projects, but in the current one I'm encountering a problem that I can't understand; I attach the code snippet below;
basically the properties
EndpointDescriptor.UrlString contain "opc.tcp://10.0.0.3:30005/Marcom/S7.Net"
NodeDescriptor.NodeId.ExpandedText contain "nsu=urn:terminalsrv:MarcomOPCServerUAS7Net ;ns=1;s=Termosaldatrice.WO.RD.LifeBit
are valued correctly (check in debug)
The same values ​​entered via the DEMO OPC-UA app work correctly
Despite this ErrorMessageBrief always contains the following message
"Status is not good: {BadNodeIdUnknown}. The node id refers to a node that does not exist in the server address space."
What can I do, check?
ReadArgumentsCicli=CreateObject("OpcLabs.BaseLib.Collections.ElasticVector") ReadArgumentC="ReadArgumentsC" &ReadArgumentC=CreateObject("OpcLabs.EasyOpc.UA.OperationModel.UAReadArguments") &ReadArgumentC..EndpointDescriptor.UrlString=alltrim(this.uri) &ReadArgumentC..NodeDescriptor.NodeId.ExpandedText=alltrim(this.node)+alltrim(&mnemonicletto) if this.oParentObject.w_LAUTENTI="S" &ReadArgumentC..EndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName=alltrim(this.oParentObject.w_LUSER) &ReadArgumentC..EndpointDescriptor.UserIdentity.UserNameTokenInfo.Password =alltrim(.w_LPASSWORD) endif ReadArgumentsCicli.Add(&ReadArgumentC) ValueresultC=oClient.ReadValueList(ReadArgumentsCicli) resultC=ValueresultC.Item[0] error="" error=resultC.ErrorMessageBrief"
Last edit: 15 Sep 2023 07:54 by info@software2000.it.
