Unhandled exception in C++ WriteMultipleItemValues
15 Aug 2023 17:25 #12000 by ZParham
Perfect, thank you so much!
15 Aug 2023 15:56 #11998 by support
There is a bug in the example.
Here is the fixed part:
CComSafeArray<VARIANT> ArgumentsArray(8);
ArgumentsArray.SetAt(0, _variant_t((IDispatch*)ItemValueArguments1Ptr));
ArgumentsArray.SetAt(1, _variant_t((IDispatch*)ItemValueArguments2Ptr));
ArgumentsArray.SetAt(2, _variant_t((IDispatch*)ItemValueArguments3Ptr));
ArgumentsArray.SetAt(3, _variant_t((IDispatch*)ItemValueArguments4Ptr));
ArgumentsArray.SetAt(4, _variant_t((IDispatch*)ItemValueArguments5Ptr));
ArgumentsArray.SetAt(5, _variant_t((IDispatch*)ItemValueArguments6Ptr));
ArgumentsArray.SetAt(6, _variant_t((IDispatch*)ItemValueArguments7Ptr));
ArgumentsArray.SetAt(7, _variant_t((IDispatch*)ItemValueArguments8Ptr));
CComVariant vArgumentsArray(ArgumentsArray);
LPSAFEARRAY pArgumentsArray = ArgumentsArray.Detach();
CComSafeArray<VARIANT> ResultArray;
ResultArray.Attach(ClientPtr->WriteMultipleItemValues(&vArgumentsArray));
ArgumentsArray.Attach(pArgumentsArray);
There are two differences:
1) additional variable - CComVariant vArgumentsArray(ArgumentsArray);
2) use of that variable - the WriteMultipleItemValues call now uses &vArgumentsArray and not &pArgumentsArray
Will be fixed in the upcoming version. Good catch!
The following user(s) said Thank You: ZParham
14 Aug 2023 16:19 #11987 by ZParham
We are using the project at C:\Program Files (x86)\Software Toolbox OPC Data Client 2022.2\Examples-COM\CPP\VisualStudio\Win32\WriteMultipleItemValues unmodified.
ReadMultipleItems in the same solution that is launched with that project runs successfully with no errors.
We have tried this with both the kit server (OPCLabs.KitServer.2) and TOP Server, and saw the same error with both.
14 Aug 2023 16:09 #11986 by support
1. In the same project, are they calling some other methods on the _EasyDAClient - such as ReadXXXX? If so, do they work?
2. Which target OPC server are they connecting to?
14 Aug 2023 14:58 #11985 by ZParham
Hello!
We are doing some troubleshooting for a customer using OPC Data Client version 2022.2 in C++ with Visual Studio 2022.
When we attempt to run WriteMultipleItemValues from WriteMultipleItemValues.vcxproj, we receive an unhandled exception with an HRESULT of "E_NOINTERFACE," screenshot attached.
We are having a hard time troubleshooting this no interface supported error.
What are we missing here to get WriteMultipleItemValues to work?
Thank you, as always!
Zachary Parham
    Time to create page: 0.171 seconds
