ApplicationName used for certificate in C++ COM Project
21 Jun 2023 13:59 #11832 by csm
All working, thanks for the advice.
21 Jun 2023 09:16 #11830 by support
21 Jun 2023 09:15 #11829 by csm
I have just realised my error. I was using an underscore within the __uuidof call i.e.
_EasyUAApplicationPtr easyAppPtr(__uuidof(_EasyUAApplication))
but using
_EasyUAApplicationPtr easyAppPtr(__uuidof(EasyUAApplication))
Creates the object. I'll look at adjusting the ApplicationName now.
Colin
21 Jun 2023 08:31 #11828 by csm
Unfortunately I still get the same "Class not registered" error after uninstalling 2022.2 and installing 2023.1 and rebuilding the C++ application.
I also tested and got the same error when adding the line to one of your examples ..\Examples-COM\CPP\VisualStudio\Win32\UADocExamples\_EasyUAClient\DiscoverLocalServers.Main.cpp
namespace _EasyUAClient
void DiscoverLocalServers::Main()
// Initialize the COM library
CoInitializeEx(NULL, COINIT_MULTITHREADED);
_EasyUAApplicationPtr easyAppPtr(__uuidof(_EasyUAApplication));
Should this work or should I use a different way to set the ApplicationName (or other certificate details) with C++/COM in 2023.1?
Colin
20 Jun 2023 13:54 #11827 by support
OK, I am now reading your original post better, and in fact, it appears that you have already looked at the documentation that is for 2023.1.
And, the method you have "guessed" should be the right one. I.e. instantiate the EasyUAApplication object. It is not in 2022.2 but it is in 2023.1.
Please uninstall the old version first, in order to prevent possible conflicts.
The following user(s) said Thank You: csm
20 Jun 2023 13:50 #11826 by csm
Thanks for the quick response. Yes I can upgrade to 2023.1.
Colin
20 Jun 2023 13:25 #11825 by support
I will give you the answer, but let me ask first: Can't you upgrade to version 2023.1?
The reason I am asking that the location of these parameters have changed in 2023.1 - so if you can upgrade, or anticipate an upgrade anyway, it would be better to do it in the new way already.
20 Jun 2023 13:22 #11824 by csm
I am working with an unmanaged C++ project and would like to be able to set the "ApplicationName" property. In C# it is done as follows:
// Set the application name, which determines the subject of the client certificate.
// Note that this only works once in each host process.
EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationName = "QuickOPC - CSharp example application";
How can the global "EasyUAApplication" object be accessed using the C++ COM interfaces?
I tried to create an object as follows:
but this throws a "Class not registered" error.
I can access and use other QuickOPC objects, so the issue is just limited to the _EasyUAApplication class, so assume this is a special case. Can't find any examples.
I am Using QuickOPC 2022.2.
Colin
Time to create page: 0.204 seconds
