Crash with "ntdll.dll" error
24 Nov 2022 14:15 #11236 by support
QuickOPC 2018.1 had problems with newer Windows 10 editions (version 2004 and later).
The recommended way is to upgrade QuickOPC.
If that is not an option, try this: kb.opclabs.com/How_to_disable_prerequisites_boxing .
The xxxx.exe.config file will have to be placed in the same directory as you app's EXE.
The following user(s) said Thank You: federica
24 Nov 2022 08:19 #11235 by federica
I'm using QuickOPC COM, developing in C++.
On a pc of a customer I have some problem using my OPC client.
The machine continue reports crash with problems with "ntdll.dll".
The Quick OPC (2018.1) library is correcty installed and licensed.
The machine is Windows 10.
Have you never faced a problem like this?
What can I check?
Federica
