Cannot open source file stdafx.h when targetting x86
06 Sep 2022 11:57 #11086 by ZParham
Thank you very much! The customer was able to find the cause over the weekend. As you had suspected, it was a Visual Studio configuration issue.
C/C++ -> Language -> Conformance Mode was set as Yes (/permissive -). Changing this to Default solved this.
As always, thank you!
05 Sep 2022 07:21 #11085 by support
I will look at this, but give me some time. And, I think, in the meantime the customer should still work on it himself, because this is basically a language/tool issue, which has almost certainly nothing to do with our product. Most likely some misconfiguration in project settings. Does not look like the kind of issue the product tech support is for.
The following user(s) said Thank You: ZParham
02 Sep 2022 20:35 #11084 by ZParham
A customer was able to create and compile a simple OPC-UA client in Visual Studio 2019 v16.11.11 using C++ on Windows 64-bit computer. The program compiles with no errors when the Debug mode is set as x64. However, after changing the Debug mode to x86, the error "Cannot open source file stdafx.h" appears when attempting to build the project.
So far, we have tried the following:
  • Pointing stdafx.h to the root location
  • Under header files, changing the platform of stdafx.h to Win32
  • Selecting "Retarget Solution"
Below is a download link to the solution. Do you have any other suggestions on what we can attempt?
softwaretoolbox.sharefile.com/d-s60f5b38be44e4380bd6da6558a275d85
