ServerTimeStamp
14 Jun 2022 11:58 #10972 by support
Replied by support on topic ServerTimeStamp
Actually, there appears to be a standard PHP function for that: variant_date_to_timestamp .
- www.php.net/manual/en/function.variant-date-to-timestamp.php
It expects the local date/time as input, so in order to get the correct result, you will need to pass in the ServerTimestampLocal, and not ServerTimestamp.
The following user(s) said Thank You: CJiwan
14 Jun 2022 10:27 #10971 by CJiwan
Replied by CJiwan on topic ServerTimeStamp
Thanks for your answeer.
The link talk about a timestamp but not in Unix format.
But, maybe I'm stuppid :-), i do not find how to convert this timestamp to a DateTime class from PHP.
Christian
13 Jun 2022 05:39 #10967 by support
There might not be a ready-to-made function available for this, so some programming will be required.
Is the problem that
1) you do not know how is the date/time used in UAAttributeData.ServerTimestamp represented, or
2) you know how it is represented, but you do not know how to convert that representation to "yours"?
Regarding the first case: You can basically use the information listed here: docs.microsoft.com/en-us/cpp/atl-mfc-shared/date-type?view=msvc-170 .
This should be enough to write the conversion routines. But if you still have a problem, let me know.
12 Jun 2022 18:53 #10965 by CJiwan
ServerTimeStamp was created by CJiwan
In a PHP project I try to convert the ServerTimestamp (obtained in the AttributeData of the result of a reading or subscription) to the DataTime format to be able to store it in a MySQL DB.
Can you help me, i do not find the good methode.
Tanks
