error from server when writing
08 Mar 2022 11:45 #10713 by ulix86
Hi Support,
I'm trying to write to the server but I get this error. Is there anything i can do or is from on the server?
ConnessoResult 0: OPC-UA service result - (no description available) = BadSecureChannelClosed. ---- SERVICE RESULT ---- Status Code: {BadSecureChannelClosed} = 0x80860000 (2156265472) -=-=- ---- REMARKS ---- The server may have rejected the connection because it does not trust the client (e.g. certificate problem); check the diagnostics on the server side, if possible. A possible cause of this error could also be that the OPC-UA server is not running, or that it has rejected the connection due to security reasons. + The SDK action called was "Session.Write". + Following (4) events were gathered during the action on activity ID [1], in the order of first occurrence: SDK trace: Write Called. RequestHandle=12, PendingRequestCount=2 [8] SDK trace: TCPCLIENTCHANNEL SOCKET CLOSED: 00000914, ChannelId=1 [7] Exception: {Opc.Ua.ServiceResultException} BadSecureChannelClosed SDK trace: Write Completed. RequestHandle=12, PendingRequestCount=1, StatusCode=Bad + Events starting with activity ID in [] may not necessarily be related to the current action. + The client method called was 'WriteMultiple'.
