OpcUa_SecureConnection_Disconnect: Disconnecting in state 3!
05 Mar 2022 07:43 #10700 by support
I am confused now. You wrote "my KepServerEX is not connecting to iFIX OPC-UA server". This forum is forum QuickOPC client applications. Are you using QuickOPC?
If yes, what has KepServerEX connecting to iFIX OPC-UA server do with it?
If not, use the corresponding venue.
04 Mar 2022 21:42 #10699 by smbunn
I have not had access to the OPC-UA tags for a week now, the iFIX log file looks like this since then. So my KepServerEX is not connecting to iFIX OPC-UA server but seems to retry every 30 seconds. The error message below is the only thing in the error log file, repeated every 30 seconds.
What does "Disconnecting in state 3!" mean and why does it have an exclamation mark as this to me implies a fault?
04 Mar 2022 05:43 #10692 by support
What makes you think this is wrong?
What makes you think you "lost connection"? It may be just disconnecting because connection is not needed.
04 Mar 2022 02:56 #10691 by smbunn
I have lost contact with an iFIX OPC-UA server repeatedly and it is getting worse.
I pulled up the iFIX OPC-UA logs and see this every few minutes, it repeats every 30 seconds:
05:44:55.626Z|1|19C4* [uastack] NetworkThread: Message Loop started... 05:44:55.627Z|1|19C4* [uastack] OpcUa_TcpConnection_ConnectEventHandler: Transport connection established to 192.168.2.245:4840 on socket 8C396A4! 05:44:55.750Z|1|19C4* [uastack] OpcUa_Channel_ResponseAvailable: RegisterServerResponse 05:44:55.751Z|1|1B14* [uastack] OpcUa_SecureConnection_Disconnect: Disconnecting in state 3! 05:44:55.751Z|1|1B14* [uastack] OpcUa_SecureConnection_Disconnect: Disconnecting transport. 05:44:55.751Z|1|1B14* [uastack] OpcUa_TcpConnection_Delete: Stopping communication. 05:44:55.751Z|1|19C4* [uastack] NetworkThread: Stopped by stop flag. 05:44:55.751Z|1|1B14* [uastack] OpcUa_TcpConnection_Delete: Communication stopped.
Any ideas?
