Read ad Write multiple values
20 Feb 2024 17:41 #12566 by support
21 Nov 2023 13:35 #12397 by support
20 Aug 2019 06:11 #7634 by support
It looks like that we have worked on similar issue in Python before. The results array is weird - but it still can be processed. Please see www.opclabs.com/forum/general-issues-building/2466-quickopc-in-python#6436 , and attempt to extract the results (roughly) like this:
Result1 = win32com.client.Dispatch(val[0][0]) Result2 = win32com.client.Dispatch(val[0][1]) Result3 = win32com.client.Dispatch(val[0][2]) Vtq1 = Result1.Vtq Vtq2 = Result2.Vtq Vtq3 = Result3.Vtq
17 Aug 2019 20:03 #7632 by Jesus Rodriguez
Hi, thanks for your reply, I just tried to run it in python. This is what I got:
import win32com.client
ReadItemArguments1 = win32com.client.Dispatch("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments")
ReadItemArguments1.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2"
ReadItemArguments1.ItemDescriptor.ItemID = "Demo.Single"
ReadItemArguments2 = win32com.client.Dispatch("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments")
ReadItemArguments2.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2"
ReadItemArguments2.ItemDescriptor.ItemID = "Demo.Single"
arguments = [ReadItemArguments1, ReadItemArguments2]
client = win32com.client.Dispatch('OpcLabs.EasyOpc.DataAccess.EasyDAClient')
results = client.ReadMultipleItemValues(arguments)
There is no error at this point but still I think is not correct since I cannot get the values.
Thank you for your help
14 Aug 2019 07:51 #7621 by support
There are ReadMultipleItems and ReadMultipleItemValues methods for this purpose. See e.g. opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ding%20just%20the%20value.html .
I do not have Python example at hand. hopefully you can derive it from code given in other languages. If you run into an issue, let me know here. Here is a VBScript example for ReadMultipleItemValues:
Rem This example shows how to read values of 4 items at once, and display them. Option Explicit Dim ReadItemArguments1: Set ReadItemArguments1 = CreateObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") ReadItemArguments1.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments1.ItemDescriptor.ItemID = "Simulation.Random" Dim ReadItemArguments2: Set ReadItemArguments2 = CreateObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") ReadItemArguments2.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments2.ItemDescriptor.ItemID = "Trends.Ramp (1 min)" Dim ReadItemArguments3: Set ReadItemArguments3 = CreateObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") ReadItemArguments3.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments3.ItemDescriptor.ItemID = "Trends.Sine (1 min)" Dim ReadItemArguments4: Set ReadItemArguments4 = CreateObject("OpcLabs.EasyOpc.DataAccess.OperationModel.DAReadItemArguments") ReadItemArguments4.ServerDescriptor.ServerClass = "OPCLabs.KitServer.2" ReadItemArguments4.ItemDescriptor.ItemID = "Simulation.Register_I4" Dim arguments(3) Set arguments(0) = ReadItemArguments1 Set arguments(1) = ReadItemArguments2 Set arguments(2) = ReadItemArguments3 Set arguments(3) = ReadItemArguments4 Dim Client: Set Client = CreateObject("OpcLabs.EasyOpc.DataAccess.EasyDAClient") Dim results: results = Client.ReadMultipleItemValues(arguments) Dim i: For i = LBound(results) To UBound(results) WScript.Echo "results(" & i & ").Value: " & results(i).Value Next
13 Aug 2019 05:36 #7620 by admin
Replied by admin on topic Read ad Write multiple values
Please be [patient. Will reply later this week, as soon as possible. We have a vacation period.
12 Aug 2019 18:26 #7619 by Jesus Rodriguez
Hi
I have the following code to read and write:
value = client.ReadItemValue('', 'CoDeSys.OPC.02', '.Inputs[9]')
client.WriteItemValue('', 'CoDeSys.OPC.02', '.Inputs[9]', 7)
They work well but I would like to know how to read and write multiple values in just one function. Is there any function already doing this?
