Writing ByteString
10 Jul 2019 09:13 #7509 by federica
Replied by federica on topic Writing ByteString
Thank you very much for your support.
I solved my problem with the following cast:
variant_t vArray; vArray.ChangeType(VT_ARRAY | VT_UI1, &output);
19 Jun 2019 13:49 #7448 by support
Replied by support on topic Writing ByteString
You can read the DataType attribute of the node to obtain its data type. What you get a back is a node ID of the data type; this need to be compared with the "standard" node IDS for various types, as defined in the OPC UA specification. An example of reading the data type attibute (unfortunately for .NET only) is here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20of%20a%20single%20node.html .
I do not quite understand the part about ChangeType. First of all, I think that changing type to VT_CARRAY or VT_SAFEARRAY is pointless, they are special values not meant for user code. And, VT_ARRAY is a bit that needs to OR-ed with some other scalar VT_xxxx in order to make sense. Second, in your two-line example, the contents of vString is an empty variant (VT_EMPTY), so no wonder that its type cannot be changed. You can use ChangeType on variants for e.g. converting numbers to string or converting between integer types (if the value fits into the target range) etc., but do not expect it to convert between strings and arrays and similar things.
18 Jun 2019 13:44 #7444 by federica
I found a similar solution:
void WriteValue::ByteString() { CoInitializeEx(NULL, COINIT_MULTITHREADED); _bstr_t serverParam(_T("opc.tcp://localhost:4840")); _bstr_t valueParam(_T("ns=2;s=VARIABLE")); _EasyUAClientPtr ClientPtr(__uuidof(EasyUAClient)); // Obtain attribute data. By default, the Value attribute of a node will be read. try{ // Insert Content into the array: saByteArray CString writeValue (_T("TEST")); CComSafeArray <BYTE> saByteArray(256); int nRealLength = writeValue.GetLength(); saByteArray.Resize(nRealLength); for(int i = 0; i < min(nRealLength, 256); i++) { saByteArray.SetAt(i, writeValue.GetAt(i)); } CComVariant varArrayWrapper (saByteArray); _UAWriteValueArgumentsPtr WriteValueArguments1Ptr(_uuidof(UAWriteValueArguments)); WriteValueArguments1Ptr->EndpointDescriptor->UrlString = serverParam; WriteValueArguments1Ptr->NodeDescriptor->NodeId->ExpandedText = valueParam; WriteValueArguments1Ptr->Value = varArrayWrapper; CComSafeArray<VARIANT> arguments(1); arguments.SetAt(0, _variant_t((IDispatch*)WriteValueArguments1Ptr)); // Obtain values. By default, the Value attributes of the nodes will be Write. LPSAFEARRAY pArguments = arguments.Detach(); CComSafeArray<VARIANT> results; results.Attach(ClientPtr->WriteMultipleValues(&pArguments)); arguments.Attach(pArguments); // Display results for (int i = results.GetLowerBound(); i <= results.GetUpperBound(); i++) { _UAWriteResultPtr ResultPtr = results[i]; if (ResultPtr->Succeeded) _tprintf(_T("Result %d success\n"), i); else { CString msg; msg.Format(_T("Result %d: %s\n"), i, CW2T(ResultPtr->Exception->GetBaseException()->Message)); AfxMessageBox(msg); } } SAFEARRAY* pResults = results.Detach(); pArguments = arguments.Detach(); SafeArrayDestroyData(pArguments); SafeArrayDestroyData(pResults); SafeArrayDestroy(pArguments); SafeArrayDestroy(pResults); arguments.Destroy(); results.Destroy(); pArguments = NULL; pResults = NULL; } catch (const _com_error& e){ CString desc( (LPCTSTR) e.Description()); CString errorMessage(e.ErrorMessage()); } // Release all interface pointers BEFORE calling CoUninitialize() CoUninitialize(); }
I would like to improve my function in order to dinamically recognize the type of the variable to write (if "String" or "ByteString"). Any suggestion?
Now I have some problem reading the variables…
Casting the variable to VT_BSTR, VT_SAFEARRAY, VT_CARRAY or VT_ARRAY always fails.
_variant_t vString; vString.ChangeType(VT_BSTR, &output);
Can you help me?
Thank you!
Federica
15 Jun 2019 09:46 #7443 by support
You need to create a safearray of bytes from your string and pass it to the WriteValue method. The following example writes a "constant" ByteString. You can modify it to write anything you like.
void WriteValue::ByteString() { // Initialize the COM library CoInitializeEx(NULL, COINIT_MULTITHREADED); { // Instantiate the client object _EasyUAClientPtr ClientPtr(__uuidof(EasyUAClient)); // Prepare the value to be written CComSafeArray<BYTE> array(5); array.SetAt(0, 11); array.SetAt(1, 22); array.SetAt(2, 33); array.SetAt(3, 44); array.SetAt(4, 55); const CComVariant value(array); // Perform the operation ClientPtr->WriteValue( L"http://opcua.demo-this.com:51211/UA/SampleServer", // or "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer" L"nsu=http://test.org/UA/Data/;i=10230", value); } // Release all interface pointers BEFORE calling CoUninitialize() CoUninitialize(); }
The following user(s) said Thank You: federica
13 Jun 2019 12:52 #7440 by federica
Yes, I'm passing a string because my value is a CString.
13 Jun 2019 12:49 #7439 by support
what type of value are you passing to be written? Are you passing in a string? If so, that would be wrong. It should be an array of bytes.
13 Jun 2019 10:05 #7438 by federica
Writing ByteString was created by federica
I'm using your SDK (QuickOPC 2018.1, in particular OPC-UA under COM with C++) since last year.
We usually write data through WriteValue method.
I'm connected to a Fanuc OPC-UA server and I need to write a ByteString tag.
How can I do this?
I continue to receive casting error: "Cast da 'System.String' a 'System.Byte[]' non valido."
Do you know a way for detecting the type of the tag in order to handle different data type in my source code?
Federica
