Change QuickOPC version used on development machine
23 Jan 2019 07:36 #7025 by support
For COM usage, you cannot *run* multiple versions of QuickOPC at the same computer (this is different from .NET where the versions are isolated).
You should still be able to *build* for multiple versions of QuickOPC, but in that case you need to reference the QuickOPC type libraries not by their TLBID, e.g. not
#import "libid:ecf2e77d-3a90-4fb8-b0e2-f529f0cae9c9"
but instead by pointing to the actual .TLB file for the version you want. See docs.microsoft.com/en-us/cpp/preprocessor/hash-import-directive-cpp?view=vs-2017 .
23 Jan 2019 07:27 #7024 by federica
But if I want to debug or test a different version of the library rather the last version installed, can I switch from one version to another?
Is there a way to change the version linked by the compiler?
22 Jan 2019 19:41 #7023 by support
For record, this is now answered (by yourself) in the forum thread you have referenced.
22 Jan 2019 13:24 #7020 by federica
I'm facing the problem described in this topic which is causing me compatibility problems between new versions of my application and machines with old installations of the library: www.quickopc.com/forum/quickopc-com--4/2580-property-with-a-different-name-in-the-new-release
At the moment I'm distributing version 2018.1 and I'm testing version 2018.3 of the library.
On my development machine, I installed QuickOPC version 2018.1 and 2018.3.
I need a quick way to change the version linked by the compiler. Is there a way? How can I switch from one version to another?
