ReadMultiplevalues never comes back
25 Jan 2018 12:09 #5915 by support
Hello, can you please do this (with 2018.1)?: kb.opclabs.com/Obtaining_.NET_call_stacks_in_a_COM_application .
Thank you, and best regards
25 Jan 2018 10:12 #5914 by Dq-soft
Hello Again,
i made i few more tests and the Problem is that Writemultiplevalues does not come back.
Tests with ReadMultipleValues without sendig are ok now, but if i activate Multiplewrite i have the problem that multiwrite does not come back when i plug the cable.
So my mainprogramm, that´s want to copy variables to the senderthread cannot access function Versand.add of the Senderthread and so the whole program freezes.
Kind regards
Dina
22 Jan 2018 14:50 - 25 Jan 2018 08:32 #5897 by Dq-soft
Hello again,
i tested 2018.1.
But there is still the same Problem. But now I testest like this :
Testprogram with Quickopc in Delphi on PC1 (Multplewrite and Multipleread in different threads with different entities of Quickopc, Twincat 3.1 on PC2
When i pull out the Network cable and let the cable unplugged for more than 1 Minute on PC1 ReadMultipleValue does not come back and the whole thread with Readmultiplevalues is frozen.
Also The Multiplewrite does not come back and this thread is also frozen
I waitet 10 Minutes but with no result
Kind regards
Last edit: 25 Jan 2018 08:32 by Dq-soft. Reason: New Bugs
19 Jan 2018 16:14 #5890 by support
Link sent to the email you used to register with the forums.
19 Jan 2018 16:09 #5889 by Dq-soft
Hello, that sounds good.
It would be very helpful if you can send me the link to the beta.
regards Dina
19 Jan 2018 15:41 #5888 by support
The default OperationTimeout is 2 minutes. If the method does not return after that, it is likely an issue of QuickOPC itself. We have recently fixed such an issue; however the fix will be only available i the upcoming version (2018.1), scheduled for release most likely in February.
If you are interested I can send you a private link to test the Beta version of it.
(Note: with Delphi, you will have to re-import the type libraries, as they have changed).
19 Jan 2018 15:37 #5887 by Dq-soft
Hello, I use Version 2017-2 with Delphi XE6 and Twincat 3.1 OPCUA Server
Sometimes when i switch Twincat to config mode ReadMultipleValues never comes back.
Normale i get an Error with every node i try to read like BadDeviceFailure or Timeout but sometimes the functions never comes back.
I have set FastestKeepaliveInterval to 30000 and FastestlifetimeInterval to 50000 with no result.
Is there an timeout that i can configure ?
What can i do?
regards
Dina
