Subscription Events are wrong order
22 Aug 2017 14:18 #5448 by support
Our client component is designed to deliver the event notifications to your code in the order it receives them from the server. I therefore suggest that you consult with the server vendor, because I think the order you are seeing is the order the server sent them to us.
This said, there is no "sequencing" requirements in OPC UA standard that would require the server to use any particular order, anyway. It is up to them how they implement it.
22 Aug 2017 13:01 #5447 by Dq-soft
i created a subsription to monitore 2000 variables.
to test i send every 100 MS the first 100 variables ascended by 1
eg.
V1 1
V2 1
V100 1
V1 2
V2 2
V100 2
The sending is done with WriteMultiplevalues
On serverside everything is fine but on Client side i
get the ondatachangenotification Event fired in a strange order
See testevent.csv for details
File Name: testevent.csv
File Size:1 KB
I Need the Events fired in exact the same order the values are writen.
What can i do ?
Kind Regards
Dina Quasdorf
