VB6 app in W7 is not releasing client connection to Kepware
13 Jul 2017 09:48 #5349 by support
What leads you to believe that the client connection is not terminated?
Have you tried the same with recent Kepware server version?
  • William Doherty
11 Jul 2017 15:12 - 13 Jul 2017 09:47 #5343 by William Doherty
Hi
I have a small VB6 app using a public function to read (see below) and write values to PLC via kepware.
Problem is when I exit the app, it will not terminate any client connection that it has created.
On subsequent restarts the client connection keeps getting bigger.
How do I kill all client connections when exiting the app.
Bill
Public Function ReadValue(TextString As String) As Variant On Error GoTo ErrorRoutine ' Create EasyOPC-DA component Dim Client As New EasyDAClient ' Read item value and display it ReadValue = Client.ReadItemValue("", "KEPWare.KEPServerEx.V4", TextString) 'Set Client = Nothing ' Exit Function ErrorRoutine: 'Call LogError("ReadValue", Err.Description) 'Set Client = Nothing End Function
Last edit: 13 Jul 2017 09:47 by support.
