Delphi 10.2 Tokyo copatibility
07 Aug 2017 06:32 #5413 by alr1976
Yes it works perfectly. I m using Delphi Tokyo and opclabs. I created Components that read,write change image etc. Now to read/write value i spend only 5 second
23 May 2017 17:18 - 23 May 2017 17:18 #5178 by support
We (OPC Labs) do not have explicit knowledge of somebody doing/having done this. But I suppose it should work. It is usually necessary to re-generate the component wrappers (from QuickOPC type libraries), with each new Delphi version.
Let us know if you run into problems, and we will try to help.
Last edit: 23 May 2017 17:18 by support.
  • m.baumgartner
23 May 2017 15:51 #5177 by m.baumgartner
Delphi 10.2 Tokyo copatibility was created by m.baumgartner
My team is about to upgrade our Delphi version from Delphi Seattle to Delphi Tokyo. Has anyone successfully switched to Tokyo with QuickOPC?
