connect the c++ to quickopc
04 May 2017 13:36 - 04 May 2017 14:11 #5136 by TONY CHIAM
Hi, i already change back to libid and try to connect to the matrikonopc server for omron plc. When i put the server class and item id into my coding, it comes out some error and i dont know how to solve it. Sorry, i am the newbie for opc and c++. Thank.
#include "stdafx.h" #include <atlsafe.h> #include <comutil.h> #include <Windows.h> #import "libid:BED7F4EA-1A96-11D2-8F08-00A0C9A6186D" // mscorlib using namespace mscorlib; // OpcLabs.BaseLib #import "libid:ecf2e77d-3a90-4fb8-b0e2-f529f0cae9c9" \ rename("value", "Value") using namespace OpcLabs_BaseLib; // OpcLabs.EasyOpcClassic #import "libid:1F165598-2F77-41C8-A9F9-EAF00C943F9F" \ rename("machineName", "MachineName") \ rename("serverClass", "ServerClass") using namespace OpcLabs_EasyOpcClassic; int _tmain(int argc, _TCHAR* argv[]) { // Initialize the COM library. Note: If you choose STA, you will be responsible for pumping messages. CoInitializeEx(NULL, COINIT_MULTITHREADED); // Instatiate the EasyOPC-DA client object _EasyDAClientPtr ClientPtr(__uuidof(EasyDAClient)); _DAReadItemArgumentsPtr ReadItemArguments1Ptr(_uuidof(DAReadItemArguments)); ReadItemArguments1Ptr->ServerDescriptor->ServerClass = L"Matrikon.OPC.OMRON.1"; ReadItemArguments1Ptr->ItemDescriptor->ItemId = L"first/PLC1/#OfflineMode"; CComSafeArray<VARIANT> ArgumentsArray(1); ArgumentsArray.SetAt(0, _variant_t((IDispatch*)ReadItemArguments1Ptr)); LPSAFEARRAY pArgumentsArray = ArgumentsArray.Detach(); CComSafeArray<VARIANT> ResultArray; ResultArray.Attach(ClientPtr->ReadMultipleItems(&pArgumentsArray)); ArgumentsArray.Attach(pArgumentsArray); for (int i = ResultArray.GetLowerBound(0); i <= ResultArray.GetUpperBound(0); i++) { _DAVtqResultPtr DAVtqResultPtr(ResultArray[i]); _ExceptionPtr ExceptionPtr(DAVtqResultPtr->Exception); if (ExceptionPtr != NULL) { _variant_t exceptionAsString(ExceptionPtr->ToString); _tprintf(_T("results(%d).Exception.ToString(): %s\n"), i, exceptionAsString.bstrVal); continue; } _DAVtqPtr DAVtqPtr(DAVtqResultPtr->Vtq); _variant_t vtqAsString(DAVtqPtr->ToString); _tprintf(_T("results(%d).Vtq.ToString(): %s\n"), i, vtqAsString.bstrVal); } // Release all interface pointers BEFORE calling CoUninitialize() ResultArray.Destroy(); ClientPtr = NULL; CoUninitialize(); TCHAR line[80]; _putts(_T("Press Enter to continue...")); _fgetts(line, sizeof(line), stdin); return 0; }
error C2039: 'ItemId' : is not a member of 'OpcLabs_EasyOpcClassic::_DAItemDescriptor'
1> c:\users\user\documents\visual studio 2010\projects\opctest3\opctest3\debug\opclabs.easyopcclassic.tlh(2350) : see declaration of 'OpcLabs_EasyOpcClassic::_DAItemDescriptor'
Last edit: 04 May 2017 14:11 by support.
04 May 2017 09:19 #5134 by support
Replied by support on topic connect the c++ to quickopc
I do not understand why you have replaced the #import-s with "libid:" with absolute file paths.
Use the #import-s precisely as in our example. If that gives a problem, tell me what the problem is.
04 May 2017 07:44 - 04 May 2017 09:16 #5133 by TONY CHIAM
// $Header: $ // Copyright (c) CODE Consulting and Development, s.r.o., Plzen. All rights reserved. // ReadMultipleItems.cpp : Defines the entry point for the console application. // #include "stdafx.h" #include <atlsafe.h> #include <comutil.h> #include <Windows.h> // mscorlib #import "C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.6.1\mscorlib.dll" using namespace mscorlib; //OpcLabs.BaseLib #import "C:\Program Files (x86)\OPC Labs QuickOPC 2016.2\Lib\OpcLabs.BaseLib.tlb" \ rename("value", "Value") using namespace OpcLabs_BaseLib; // OpcLabs.EasyOpcClassic #import "C:\Users\User\Documents\visual studio 2010\Projects\opctest3\OpcLabs.EasyOpcClassic.tlb" \ rename("machineName", "MachineName") \ rename("serverClass", "ServerClass") using namespace OpcLabs_EasyOpcClassic; int _tmain(int argc, _TCHAR* argv[]) { // Initialize the COM library. Note: If you choose STA, you will be responsible for pumping messages. CoInitializeEx(NULL, COINIT_MULTITHREADED); // Instatiate the EasyOPC-DA client object _EasyDAClientPtr ClientPtr(__uuidof(EasyDAClient)); _DAReadItemArgumentsPtr ReadItemArguments1Ptr(_uuidof(DAReadItemArguments)); ReadItemArguments1Ptr->ServerDescriptor->ServerClass = L"Matrikon.OPC.OMRON.1"; ReadItemArguments1Ptr->ItemDescriptor->ItemId = L"Test1/Test/P_MAX_CYCLE_TIME"; CComSafeArray<VARIANT> ArgumentsArray(1); ArgumentsArray.SetAt(0, _variant_t((IDispatch*)ReadItemArguments1Ptr)); LPSAFEARRAY pArgumentsArray = ArgumentsArray.Detach(); CComSafeArray<VARIANT> ResultArray; ResultArray.Attach(ClientPtr->ReadMultipleItems(&pArgumentsArray)); ArgumentsArray.Attach(pArgumentsArray); for (int i = ResultArray.GetLowerBound(0); i <= ResultArray.GetUpperBound(0); i++) { _DAVtqResultPtr DAVtqResultPtr(ResultArray[i]); _ExceptionPtr ExceptionPtr(DAVtqResultPtr->Exception); if (ExceptionPtr != NULL) { _variant_t exceptionAsString(ExceptionPtr->ToString); _tprintf(_T("results(%d).Exception.ToString(): %s\n"), i, exceptionAsString.bstrVal); continue; } _DAVtqPtr DAVtqPtr(DAVtqResultPtr->Vtq); _variant_t vtqAsString(DAVtqPtr->ToString); _tprintf(_T("results(%d).Vtq.ToString(): %s\n"), i, vtqAsString.bstrVal); } // Release all interface pointers BEFORE calling CoUninitialize() ResultArray.Destroy(); ClientPtr = NULL; CoUninitialize(); TCHAR line[80]; _putts(_T("Press Enter to continue...")); _fgetts(line, sizeof(line), stdin); return 0; }
Last edit: 04 May 2017 09:16 by support.
03 May 2017 20:19 #5131 by support
Please post your project (zipped) here.
03 May 2017 15:41 #5130 by TONY CHIAM
i import the mscorlib.dll into the programming and start debug, it come out the error -
fatal error C1083: Cannot open type library file: 'c:\program files (x86)\reference assemblies\microsoft\framework\.netframework\v4.6.1\mscorlib.dll': Error loading type library/DLL.
Thank for replying
03 May 2017 08:55 #5129 by support
Please describe the problem - the error message, and any other available details.
03 May 2017 06:08 #5128 by TONY CHIAM
when i copy the readmultipleitem file to a new file and try to debug, the import of the mscorlib have the problem. How i can solve the problem?? THANK
01 May 2017 07:26 #5123 by support
For information about the libraries that need to be referenced, see e.g.:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ame.html#COM%20Components.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...pment%20Libraries%20(COM).html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0the%20Components%20(COM).html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...nts%20for%20OPC%20Classic.html
In C++, after having installed QuickOPC, you basically just need to add the #import directives to the code, as shown in the code samples.
For example, from EasyOPCDADemoDlg.h file in the EasyOPCDADemo project:
#import "libid:BED7F4EA-1A96-11D2-8F08-00A0C9A6186D" // mscorlib using namespace mscorlib; #import "System.Drawing.tlb" using namespace System_Drawing; #import "System.Windows.Forms.tlb" using namespace System_Windows_Forms; // OpcLabs.BaseLib #import "libid:ecf2e77d-3a90-4fb8-b0e2-f529f0cae9c9" \ rename("value", "Value") using namespace OpcLabs_BaseLib; #import "libid:A0D7CA1E-7D8C-4D31-8ECB-84929E77E331" // OpcLabs.BaseLibForms using namespace OpcLabs_BaseLibForms; // OpcLabs.EasyOpcClassic #import "libid:1F165598-2F77-41C8-A9F9-EAF00C943F9F" \ rename("machineName", "MachineName") \ rename("serverClass", "ServerClass") using namespace OpcLabs_EasyOpcClassic; #import "libid:E15CAAE0-617E-49C6-BB42-B521F9DF3983" // OpcLabs.EasyOpcUA using namespace OpcLabs_EasyOpcUA; #import "libid:2C654FA0-6CD6-496D-A64E-CE2D2925F388" // OpcLabs.EasyOpcForms using namespace OpcLabs_EasyOpcForms;
Regarding connection to your specific server, I suggest that you start by determining its ProgID and then an ItemID of some "tag" in the server, and modify our example(s) with this information.
29 Apr 2017 17:11 #5121 by TONY CHIAM
i using the classic data access. What dll. or lib. should i add to the c++ in order to make it success. Besides, i need to do what process in the quickopc part?
29 Apr 2017 17:06 #5120 by TONY CHIAM
Hi, i doing a project related to connect the visual studio c++ with the CP1E Omron PLC. How do i using quickopc as client to connect the c++?
