VBA: How to get a Word from opc-ua server?
07 Aug 2015 13:11 #3481 by support
Unfortunately this is a question that should be directed to the OPC server vendor.
On our side, as long as you provide a valid NodeId and the server returns a value, we will give you the value (sometimes with conversions necessary to adjust to the COM world).
07 Aug 2015 12:03 #3480 by LaurentzT
I'm testing your COM object in MS Access and this code works fine:
Dim strTest As String
strTest = client.ReadValue("opc.tcp://STP-OPC-01.domain1.local:55101?None? opcfoundation.org/UA/SecurityPolicy#None ", "ns=3;s=s7400.db500.88,x0") 'bool
strTest = client.ReadValue("opc.tcp://STP-OPC-01.domain1.local:55101?None? opcfoundation.org/UA/SecurityPolicy#None ", "ns=3;s=s7400.db500.89,b") 'Byte
strTest = client.ReadValue("opc.tcp://STP-OPC-01.domain1.local:55101?None? opcfoundation.org/UA/SecurityPolicy#None ", "ns=3;s=s7400.db500.90,w") 'Int
but I don't know the syntax to get a Dint, Word, DWord, Real, Date, Time, Char and String.
Any idea?
db500 is the database
88 is the address
x0 is the datatype
Thanks!
