delphi
26 Jan 2015 19:29 #2647 by support
Replied by support on topic delphi
Live Binding is not supported in COM-based tools (Delphi).
The recently released COM support for OPC UA specs (in QuickOPC version 5.32) has actually been tested with Delphi XE7. The existing COM support for OPC Classic specs pre-dates this, is implemented differently, and has been tested with earlier Delphi versions only. We are currently completely re-implementing the COM support for OPC Classic - it will be done in the same way as is currently for OPC UA, with much broader object model. This should be released in upcoming version 5.33, and will be tested under Delphi XE7 in the same way as OPC UA is.
26 Jan 2015 19:11 #2646 by alr1976
delphi was created by alr1976
With delphi works livebinding? And support delphi xe7?
