Connecting within SQL Server
- niels@opsdata.com
- Visitor
If you are on an old QuickOPC version, in this case 5.32 or earlier (I think it is unlikely), then you might have a reason to need this document, and in this case we can make it accessible to you.
- niels@opsdata.com
- Visitor
QuickOPC-COM".
- RickMerritt
Topic Author
- Offline
- Senior Member
- Thank you received: 0
- RickMerritt
Topic Author
- Offline
- Senior Member
All I did yesterday was downloaded QuickOPC 5.31 from your site and ran the install
I added the OA procedures to SQL Server
Was there any additional steps required? I was able to run one of the .net examples and it worked correctly.
This is on a Windows Server 2008 R2 Enterprise computer
'OPCLabs.EasyDAClient.5.1'
to
'OPCLabs.EasyDAClient.5.2'
This new ProgID of the component is documented in the manuals, but not all examples have been updated.
- RickMerritt
Topic Author
- Offline
- Senior Member
QuickOPC-COM' document to try to get a stored procedure to access an OPC server.
I installed the OA Procedures as instructed. Whenever I try to execute this portion of the code:
EXEC @hr = sp_OACreate 'OPCLabs.EasyDAClient.5.1', @easyDAClient OUT, 4;
I get the error:
-2147221005
Msg 50000, Level 16, State 1, Line 13
Error Creating COM Component 0x800401f3, ODSOLE Extended Procedure, Invalid class string
Any idea on how to fix this??
