- Thank you received: 0
Live Binding doesn't work on 'Progress Bar'
If You want You can contact me at e-mail: d.tomov@solarpro.bg and I will reply with the settings how to connect to the OPC Server I'm using.
It could be that the problem is not so straightforwardly linked to the Cache/Device as it seems at first glance.
Can we get a hold of the OPC server for our test here?
Yes, an "error" (an exception) means that no value/timestamp/quality could be obtained from the OPC
server - and therefore there is no OPC Quality to speak about in case of error.
And yes, with our component you need to use the ReadItem method in order to get access to the full quality value. The ReadItemValue WAITS (or times out) until the quality becomes Good, but you do not get the quality value from it.
Here is what I get when trying to read from Device:
The inner exception details show the following:
I tried to make the timeouts longer , but that gave no different outcome/result.
Receiving the exception means that i didn't receive bad OPC quality, right ?
Also to receive the OPC quality I suppose I need to use ReadItem Method , not ReadItemValue Method ?
And, out of curiosity, what happens if you read from Device? Do you get some kind of Bad OPC quality, or an exception?
(below, attempting to attach your last PNG, converted to JPG)
Now I have other issue:
I'm trying to read a value 'short integer' from an OPC Server (RcWare Vision of Domat Control).
And when trying manually to read a value through written programing code I have success only when implicitly specify that i want to read from Cache.
That I suppose is a server issue (reading is successful only from cache).
But when i do Live Binding and specify reading from cache I can't read the value.
I'm using for the probe simple Windows Form Application with one TextBox.
Here are the settings of the LiveBinding:
dox.bg/files/dw?a=7924ae6b56 ( again PNG wasn't let to upload )
Here is the working code, that successfully reads from cache:
you can see the ProgressBar working with LiveBinding, if (under our group in Start Menu) you run the Live Binding Demo.
Most likely reason for your problem is that the ProgressBar.Value is an Int32, but the canonical type of the OPC item you are binding is VT_R8 (a floating point - double). Floats cannot be generally converted to integers by the binding mechanism. In order to overcome this, in the Binding properties->Source->ItemDescriptor, set the RequestedDataType to I4.
Note: I have now "relaxed" some of the upload setting for the Forums, so hopefully the PNG upload will work next time.
Zbynek Zahradnik
(below is the image from your previous post, as JPG)
I have the following problem:
I'm using VS2010 (also tried VS2012) and Live Binding on TextBox is working for example,
but when i try to Live Bind a Value to a ProgresBar it doesn't work.
I attach a screenshot of the settings for the Live Binding.
I'm using for the test - OPCLabs.KitServer.2
and item "Boilers.Boiler #1.Pipe1001.ValveX001.Input" .
For some reason I can't attach the image so i uploaded here dox.bg/files/dw?a=6c6d19ebe4 .
As I said when bind is done to TextBox value get refreshed every 1 second, but on ProgressBar I have no change.
Thank you for your time.
