Where can I download Runtime license (I have site license)
08 Aug 2017 05:50 - 25 Aug 2017 02:03 #5418 by qiuyujx5
I've figured out. According to another post in this forum, I manually added the registry on target machine and then I can use the License Manager to install the license now. I think it should works, though it has not reached 30 minutes yet.
Just added to help if any others have the same issue.
If you are running your deployed program on 32bit Windows, you need to add an empty key:
HKEY_LOCAL_MACHINE\SOFTWARE\Licensing\QuickOPC\Multipurpose
If it is 64bit Windows, then
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Licensing\QuickOPC\Multipurpose
Then you can use the license manager to install your key file.
Alternatively, you can export the "Multipurpose" key to a ".reg" file, and run this file on other deployment machines, so that you don't have to manually import the license using license manager. You can get rid of it.
Last edit: 25 Aug 2017 02:03 by qiuyujx5. Reason: Added solution to the problem
08 Aug 2017 05:47 #5417 by support
Which version of QuickOPC you are using please?
08 Aug 2017 04:30 #5416 by qiuyujx5
But how could I install the license on deployment machine? The "component" is empty if I run License Manager on the deployment machine (There is no QuickOPC installed on this machine).
26 Jul 2017 09:08 #5381 by support
The same license is for the development and for the runtime purposes.
26 Jul 2017 06:26 #5380 by pandora303
Hello
I have a ultimate site license for QuickOPC (order number:517879843).
I'm trying to test my client application on an other machine. I think first of all I have to install
runtime license to that machine.
Where can I download runtime license (*.bin file)
