How to use PercentDeadband
Consider reporting it to the server vendor then...
- goosvanbeek
Topic Author
- Offline
- Platinum Member
- Thank you received: 4
I tried it with the original OpcFoundation dll's. Worked fine with the OPCLabs.KitServer.2, but not with the Freelance2000OPCServer.110.1 server.
Thanks for the suggestion.
Goos van Beek.
This can be a problem on the server side. Have you tried with some other OPC client? If not, please do so.
If you get the same problem with some other OPC client, then it is most likely a problem on the server side and we would not be able to do anything about it. The workaround is add filtering code on the client side, but that of course does not reduce the amount of communication between the OPC client and the server, which is one of the reasons the PercentDeadband exists.
If it works with some other client, please post here the details of that test, and we will work on it further.
- goosvanbeek
Topic Author
- Offline
- Platinum Member
Do you have any suggestions for what I can do about it?
Windows Server 2019
OpcLabs 5.61.241 (Nuget)
- goosvanbeek
Topic Author
- Offline
- Platinum Member
It's not that urgent, I'll wait for the upcoming version.
Thanksfor your reply.
Goos van Beek.
yes, you are right - there is a bug in QuickOPC in this version.
How urgent is it for you to get it fixed? (unless it is urgent, it will get fixed into the upcoming version, 2021.1).
- goosvanbeek
Topic Author
- Offline
- Platinum Member
I'm trying to implement PercentDeadband as described in this example , but it doesn't seem to work. I don't see any difference in deadband between the percentages, even if I change it to 90%. I expected a less frequent update, based on the difference in value.
I also tested it on a ABB Freelance server, but with the same result.
Can you help me any further?
Goos van Beek.
Windows server 2019
.Net Framework 4.72
QuickOPC 5.59.1055
