How to Develop ASP.NET OPC client app
In order to do this "right", study the Concepts document that is installed with the product (or is here: www.opclabs.com/download/file/181-concepts-quickopc ), and follow the instructions in the "Application Deployment" section.
Thank you. We really appreciate your help.
We'll look into it and get back to you in case i find issues.
Is it necessary to INSTALL QUICKOPC on client's machine ? Because, when i tried running my application on different machine i am experiencing "x86_OpcLabs.EasyOpcClassicRaw_5.30.1034.1.dll" Error. Please find attached image file
Code written on Page_Load of Default.aspx.cs is below -
var client = new OpcLabs.EasyOpc.DataAccess.EasyDAClient();
//object value = client.ReadItemValue("", "OPCLabs.KitServer.2", "Demo.Single");
object value = client.ReadItemValue("MACHINENAME", "OPCLabs.KitServer.2", "Demo.Single");
txtOPCValue.Text = (value == null) ? "" : value.ToString();
I am going good or i need to follow some other way. Please help
Best Regards
Amod
Most QuickOPC methods take the first parameter as machine name, as second parameter as the ProgID of the server. You can therefore take the code from the examples, and modify it to connect to a different computer, and a different server.
Also, the methods of QuickOPC are not limited to work with just a single OPC server. You can freely mix calls and refer to multiple different servers; it will just work.
The QuickOPC methods give you the ability to access the data (reading, writing, subscriptions). You can also explore "what's in there" by using the browsing methods. All the OPC stuff is hidden inside the component. You need to write the code "around it" that does whatever your application is supposed to do with the data.
Thank you ,
I have installed QuickOPC 5.30 and it worked. Now, I can see bunch of applications.
As you mentioned that these applications use test server.
But if we have an OPC SERVER; how can we customize it to interface with this OPC Server?
Scenario :
There is an OPC server installed on my machine. And there is another machine, I want to browse the tags from (client machine) which is a different machine than Server (i.e my machine where OPC server is installed).
Secondly, we are developing a database application for large section of industries and will have various OPC servers. We want to develop OPC client(s) to be able access these servers (not simultaneously) while data recording is done in our application through this client.
Can you please advise us?
Amod Vardhan
I was assuming you are using QuickOPC 5.30.
In QuickOPC 5.23, open the other solution – the one that does not say “VS 2010+ Only”.
Thanks alot for your reply.
I have installed "QuickOPC 5.23.exe" but as i have clicked on Visual C# Examples going through following path (see image 1). I Clicked on Visual C# Examples (VS2010 + Only). Though this opens a project in VS 2010 but there is no Web Directory( See Image 2). You can see There is only Console directory, no Web.
Attachment 1.png not found
Attachment 2.png not found
Here is what I suggest you do:
1. Download and install QuickOPC ( www.opclabs.com/downloads ). It’s a free trial.
2. In the Windows Start menu, locate the OPC Labs - QuickOPC submenu, and then select Examples (Source Code) -> Visual C# Examples. It will open a Visual Studio solution with the examples.
3. There are projects for various technologies in this solution. What you need to look at are the projects under the “Web” folder – they deal with ASP.NET.
When you install QuickOPC, it will also install a “test” (simulation) OPC server of ours. This is the server all our examples connect to, and you can use it to develop your application as well.
Please feel free to ask any additional questions.
Would it be OK if I put our conversation (anonymized) to our Online Forums, so that others can benefit from it as well, and we continue it there?
No problem.
Let’s first clarify what you are trying to achieve.
Is it my correct understanding that
1. You already have (or there will be) an OPC Server that provides the data. Do you know which server it is, and/or at least which OPC specifications it supports? (OPC-DA, A&E, Unified Architecture?)
Re- Right now, We don't have server, but our client has. But for testing purpose in development we want to have any simulator kind of thing which gives us the values say , dummy server
2. You want to write an ASP.NET 4.0 application that connects to the OPC Server (i.e. the application is an OPC client)?
Re- Exactly we want to develop OPC Client using .Net 4.0 using that dummy server setup.
Sent: Wednesday, February 19, 2014 1:35 PM
Subject: Re: QuickOPC Download Form - ...
I am sorry to say, but i am totally new in this. I need your help . First of all i would like to know how installation file i need to download it for server. and how can my applicatoin , developed in ASP.NET 4.0 . communicates with Server.
Please help me with this.
