typecodes: array of string
16 May 2024 16:08 #12796 by support
Replied by support on topic typecodes: array of string
Thank you too - I am glad this works!
16 May 2024 15:13 #12795 by ulix86
Replied by ulix86 on topic typecodes: array of string
Yestarday I tried something similar with CallArguments1.SetInputFullTypeNames but I was far from your solution.
Anyway...it works!!
You solved a big problem for me.
Thank you, I really appreciated your help.
16 May 2024 11:54 #12793 by support
I know what is happening. I will try to navigate you to the right solution (which is somewhat complicated), because we do not have a ready-made example for that.
The type for these 3 arguments needs to be specified as array of strings, but with TypeCode-s, only scalars can be specified. As method overloads are not available in COM, we do not have a method overload to directly pass in what you need. But it still can be done.
You need to:
1. Use CallMultipleMethods method instead (even though you are calling just one method - you will therefore specify just one, this is fine). For a VB6 example with CallMultipleMethods, see opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...Call%20multiple%20methods.html .
2. Instead of using array of TypeCode (variable typeCodes1(10) in the example), using will use an array of strings, specifying the full .NET types. It will look something like this:
Dim typeFullNames(13) typeFullNames(0) = "System.String": inputs(0) = "LAV1" 'nome lavoro typeFullNames(1) = "System.String": inputs(1) = "LAVORO 1" 'descrizione lavoro typeFullNames(2) = "System.String": inputs(2) = "CLIENTE UNO" 'ragione Sociale cliente typeFullNames(3) = "System.String": inputs(3) = "forchetta_5" 'production dataset name: !!!deve essere lo stesso nome del programma sulla pressa typeFullNames(4) = "System.String": inputs(4) = "FORCHETTA" 'ProductionDatasetDescription typeFullNames(5) = "System.String[]": inputs(5) = materiale 'Materiale typeFullNames(6) = "System.String[]": inputs(6) = articolo 'Articolo typeFullNames(7) = "System.String[]": inputs(7) = descart 'descrizione articolo typeFullNames(8) = "System.Boolean": inputs(8) = False 'continua a lavoro conluso typeFullNames(9) = "System.UInt64": inputs(9) = 10000 'pezzi da fare typeFullNames(10) = "System.UInt64": inputs(10) = 10000 'box pezzi da fare typeFullNames(11) = "System.Double": inputs(11) = 0 'expected cycle time typeFullNames(12) = "System.String": inputs(12) = "Mould1" 'MouldID: Codice Stampo typeFullNames(13) = "System.UInt32": inputs(13) = 8 'num.cavities
3. You will remove the type codes from the example, and modify the example to use
CallArguments1.SetInputFullTypeNames typeFullNames
to specify the types before calling the method
16 May 2024 11:09 #12792 by ulix86
Thank you for your quick response.
I try to change the code with your tips but unfortunately I recive this error now:
*** Failure: mscorlib: L'oggetto deve implementare IConvertible. + Attempting to change an object of type "System.String[]" to type "System.String". + The client method called was 'CallMultipleMethods'.
it seems that the code stops before write. I attached the wireshark readresponse.
(it seems as if it doesn't accept typecode 18 for string arrays)
Any more ideas?
16 May 2024 10:25 #12791 by support
This may require more changes, but if the right type for arguments 5,6,7 is indeed an array of strings, then when are you doing this?
typeCodes(5) = 18: inputs(5) = materiale(0) 'Materiale typeCodes(6) = 18: inputs(6) = articolo(0) 'Articolo typeCodes(7) = 18: inputs(7) = descart(0) 'descrizione articolo
It seems to me that it should be
typeCodes(5) = 18: inputs(5) = materiale 'Materiale typeCodes(6) = 18: inputs(6) = articolo 'Articolo typeCodes(7) = 18: inputs(7) = descart 'descrizione articolo
I am not saying this is the whole problem, but it is at least a part of the problem. If changing it does not help, please capture the Wireshark with this new code again, so that I can closer to the cause.
16 May 2024 10:05 #12790 by ulix86
I have a problem with a CallMethod in OpcUA COM (Visual Basic 6.0)
When I call the method I recive the error below (BadInvalidArgument).
*** Failure: OpcLabs.EasyOpcUA: OPC-UA service result - An error specific to OPC-UA service occurred (status code: BadInvalidArgument). Details follow. ---- SERVICE RESULT ---- Status Code: {BadInvalidArgument} = 0x80AB0000 (2158690304) + The client method called was 'CallMultipleMethods'.
I checked with WireShark the difference between UaExpert method call (it works properly) and my call in VB6 (not working) and I found a difference in input(5), input(6), input(7) . (code below)
In the UAExpert method they are 3 Array of String.
In my VB6 method I assigned 3 String (Typecode=18).
I guess that's the problem. Do you know the correct TypeCode of an array of String?
(I also attached the correct wireshark call in UaExpert)
OutputText = "" Dim inputs(13) Dim typeCodes(13) Dim materiale(0) As String Dim articolo(0) As String Dim descart(0) As String materiale(0) = "m1" articolo(0) = "m2" descart(0) = "m3" typeCodes(0) = 18: inputs(0) = "LAV1" 'nome lavoro typeCodes(1) = 18: inputs(1) = "LAVORO 1" 'descrizione lavoro typeCodes(2) = 18: inputs(2) = "CLIENTE UNO" 'ragione Sociale cliente typeCodes(3) = 18: inputs(3) = "forchetta_5" 'production dataset name: !!!deve essere lo stesso nome del programma sulla pressa typeCodes(4) = 18: inputs(4) = "FORCHETTA" 'ProductionDatasetDescription typeCodes(5) = 18: inputs(5) = materiale(0) 'Materiale typeCodes(6) = 18: inputs(6) = articolo(0) 'Articolo typeCodes(7) = 18: inputs(7) = descart(0) 'descrizione articolo typeCodes(8) = 3: inputs(8) = False 'continua a lavoro conluso typeCodes(9) = 12: inputs(9) = 10000 'pezzi da fare typeCodes(10) = 12: inputs(10) = 10000 'box pezzi da fare typeCodes(11) = 14: inputs(11) = 0 'expected cycle time typeCodes(12) = 18: inputs(12) = "Mould1" 'MouldID: Codice Stampo typeCodes(13) = 10: inputs(13) = 8 'num.cavities 'typeCodes1(0) = 3 ' TypeCode.Boolean 'typeCodes1(1) = 5 ' TypeCode.SByte 'typeCodes1(2) = 6 ' TypeCode.Byte 'typeCodes1(3) = 7 ' TypeCode.Int16 'typeCodes1(4) = 8 ' TypeCode.UInt16 'typeCodes1(5) = 9 ' TypeCode.Int32 'typeCodes1(6) = 10 ' TypeCode.UInt32 'typeCodes1(7) = 11 ' TypeCode.Int64 'typeCodes1(8) = 12 ' TypeCode.UInt64 'typeCodes1(9) = 13 ' TypeCode.Single 'typeCodes1(10) = 14 ' TypeCode.Double 'typeCodes1(11) = 18 ' TypeCode.String ' Instantiate the client object Dim Client As New EasyUAClient ' Perform the operation On Error Resume Next Dim outputs As Variant outputs = Client.CallMethod( _ Server, _ "ns=8;i=5015", _ "ns=8;i=7006", _ inputs, _ typeCodes) If Err.Number <> 0 Then OutputText = OutputText & "*** Failure: " & Err.Source & ": " & Err.Description & vbCrLf Exit Sub End If On Error GoTo 0 ' Display results Dim i: For i = LBound(outputs) To UBound(outputs) On Error Resume Next OutputText = OutputText & "outputs(" & i & "): " & outputs(i) & vbCrLf If Err <> 0 Then OutputText = OutputText & "*** Error" & vbCrLf ' occurrs with types not recognized by VB6 On Error GoTo 0 Next
